Odd sputter
Like Tree2Likes
Old 13 Sep 2014, 08:11 pm
Crid's Avatar
Default Odd sputter
Hi all
My 06 na over the last week has been sputtering for all of a few second at complete stops at street lights not sure as to y. Runs fine at driving speeds. I have changed the plugs and wires a while back so I'm not sure as to what would cause this? Any insite would be great.
Thanks Corey
2006 Cruiser, Non-Turbo, 19 inch Konig Trouble rims on 225/35/19 Ironman Imove tires, Airaid CAI, E3 Plugs, msd super conductor 8.5 mm wires, Freedon Design Strut Tower Brace, Glow Shift Pillar gauges, EBC Slotted Rotors with EBC Green Stuff Ceramic Fiber Core Pads, Lowerd on Tien springs, Full Custom Kenwood Excelon sound system with 1 12" JL Audio W0, 8000k Blue hids up top and aftermarket OEM Fogs with white 8000k in bumper. Ipcw Bermuda black true led taillights with tinted reverse lights.
Old 13 Sep 2014, 08:14 pm
Default Re: Odd sputter
If your A/C is running and your radiator fan isn't working properly, at idle and slow speeds your have a problem like sputtering because of the excess engine heat.
Old 13 Sep 2014, 10:58 pm
Crid's Avatar
I won't be that it's cold here now and the engine fan is new. Does it ever so often. Like a dieing spark plug maybe? I'm not sure
Old 14 Sep 2014, 01:42 am
Originally Posted by Crid View Post
Hi all
Thanks Corey
Is your engine light on?
If so can you get the trouble codes?
Old 14 Sep 2014, 08:34 am
Crid's Avatar
No that's the thing nothing comes up stating there's an error
Old 14 Sep 2014, 10:07 am
IAC may need cleaned or replaced or air leak on hoses
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 14 Sep 2014, 11:14 am
I have read some posts that some PT Cruiser owners have used Techron fuel Injection cleaner to fix some rough idle issues. Thanks to these posts I have not replaced my plugs or plug wires yet.
Old 14 Sep 2014, 01:21 pm
LionPT's Avatar
Can't clean the IAC on G2 PT's, only replace.
Old 14 Sep 2014, 01:33 pm
LionPT,
Do you know if fuel injector cleaner cleans the IAC on second generation PT's?
Old 14 Sep 2014, 07:51 pm
Crid's Avatar
LionPT,
Thanks for the info I'll pull mine out and take a gander. So on my g2 it any be cleaned u say? What's the reason for this.
Spit & Sputter johnnyp33 Tech & Performance Forum 1 20 Aug 2012 02:49 pm
vacuum readings and sputter harveje General PT Cruiser Discussions 4 04 Aug 2012 04:00 pm
spit'n & sputter'n Sstrretch Tech & Performance Forum 9 17 Aug 2010 08:59 pm
04GT Cough, Sputter, Die!! JPMS GT General Turbo Discussions 1 11 Jun 2004 01:04 pm
...high rpm sputter... earringboy Turbo Performance 4 25 May 2003 08:48 pm
