PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   Rebuilt PCM for 2004 Turbo (http://www.ptcruiserlinks.com/forum/tech-performance-forum/54366-rebuilt-pcm-2004-turbo.html)
mycar 15 Sep 2014 01:10 pm
My 2004 Turbo with 41,000 miles gave out and was throwing code after code so after changing the two oxygen sensors and getting a rebuilt PCM got another code showing the PCM was at fault, so car computer exchange took back the rebuilt to test and reprogram then send back. Just finished installing and although not on road yet, has been idling half an hour and no Check Engine light came on...but the ABS and Brake warning light will not go out, now what to do?:search:
mycar 15 Sep 2014 03:00 pm
Re: Rebuilt PCM for 2004 Turbo
Made it to front of house then car quit running, now getting code P0508 and P0038. Looks like this is going to be never ending.
Busted_PT 15 Sep 2014 07:07 pm
So how was it decided the the pcm was the problem? Looking like your back at the begining. What was the original codes?:confused:
mycar 15 Sep 2014 10:07 pm
Starting 12 Sept my thread "At loss with PCM"...I stated original fault codes as P0032 and P0038 and P0300
Changed two oxygen sensors then got code P0562, P0300/P0201/02/03/04, P0508 and P0038
Rebuilt PCM installed and got fault code P1604. That PCM was returned and second replacement PCM, today has fault codes P0508 and P0038
The way I see it everything leads to faulty PCM...but the way things are going, I don't know Jack!
ptcruisersteve 15 Sep 2014 11:04 pm
Are the two oxygen sensors you replaced Mopar brand from the dealer?
mycar 16 Sep 2014 12:16 pm
No, I purchased Bosch Premium Sensors from O'Reilly Auto Parts....not that I really needed to replace the ones I had. The way this car spits out codes I could replace everything and still not get it right.
A friend keeps telling me to change the ignition module. If I even have one where would it be?
Busted_PT 16 Sep 2014 12:45 pm
Well you did have a low voltage code in the mix. Which can cause strange stuff. Random miss with injector codes. I would carefully check the wiring around the top part of the motor for any sight of damage like animals chewing on it or just anything that looks heavily worn. With your mileage everything should look Like new. :confused::cool:
mycar 16 Sep 2014 06:32 pm
Re: Rebuilt PCM for 2004 Turbo...FIXED
After installing (2nd) rebuilt PCM and car still throwing out codes used my code reader to erase codes then thought before check engine light came back on would give it one shot and try and get it to pass CA SMOG before light came back on. At test station was told something was not set and asked if I had changed any parts lately. Told him my whole story and he said to drive car at a steady 50 mph for ten minutes then come back. Have you ever tried to drive at 50 on freeway when cars are passing you at 75/80 mph, giving finger and honking ( I even had my emergency flashers on). Did that and came back and with diagnostic tool said the oxygen sensors were now set and could proceed with test...it PASSED! Is this a secret or am I the only one who didn't know to do this?
The Brake and ABS warning lights are still lit.
JoeX 16 Sep 2014 07:37 pm
Not everyone has to deal with emission test, In Pennsylvania, it depends on what Zip code you are in and how close to large metro area.
And yes after the power has been removed from PCM it needs to be driven about 50 miles to reset the PCM for the emission test to work with no CEL.
Under 5000 miles a year and you can get a waiver.
If the CEL is on you need to spend a min $$ to get the light to go out then they will give you another year.
Welcome To PA
ptcruisersteve 16 Sep 2014 07:53 pm
You have ABS on your 2004 PT Cruiser Turbo?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
