Without bad luck I'd have no luck at all
Old 15 Sep 2014, 03:55 pm
Default Without bad luck I'd have no luck at all
I've never been part of a forum before so I hope I'm posting this in the right location. Today I was bleeding the air out of my 07 pt cruiser's cooling system. After the job was all said and done my ac clutch seized and I serpentine belt snapped off
The good news is the AC compressor itself seems to be fine. The clutch face plate was spinning freely but the Pulley was stuck so it looks like the bearings are broken. I got my hands on the manual and have been trying to get the clutch face plate off so I could remove the pulley and have the bearings replaced but the face plate just won't come off. I removed the one bolt in the center, hit it a few time with a rubber hammer (as the manual instructed) but it's still stuck on. I tried to pry it off gently but it's still stuck on.. any suggestions? any help would be appreciated.
- Arthur
P.s. I attached a pdf of the manual
Old 15 Sep 2014, 04:19 pm
Default Re: Without bad luck I'd have no luck at all
Archie, I've moved you over to your own part of the forum so hopefully someone can figure out what your doing and give you some help. Good luck.
Old 15 Sep 2014, 04:31 pm
cruserdad1976's Avatar
so the cluch is free but the pully is froze????? thats kind of odd but i guess it could be can you get a gear puller on the pulley??? on a 07 its still been 7 years of hot and cold then pupyes like to get nice and snug
Old 15 Sep 2014, 06:41 pm
Squart some penatrating oil on the shaft an let it soak.
Old 17 Sep 2014, 05:56 pm
Thanks for all the feedback. The compressor shaft bolt (the tapped hole) looks too small to attach a gear puller to it. I borrowed a ac compressor face plate remover but that was way too large to fit in the tapped hole.. I also tried soaking it in WD40 overnight but it's still wedged on. I feel as though the repair manual is missing something but that's not likely..
Old 17 Sep 2014, 06:02 pm
[ATTACH]20140915_161905.jpg[/ATTACH]
Old 18 Sep 2014, 10:57 pm
I use Liquid Wrench or PB Blaster when I am trying to loosen something up.
Old 22 Sep 2014, 08:51 pm
And, if that doesn't work, clean thoroughly and put heat (butane torch) on the pulley.
Old 13 Nov 2014, 08:21 pm
Thank you for the help! It was a real pain but I finally pulled the thing off. I replaced the bearings and haven't had any further problems with my ac clutch going on 2 months now.. Not to say other unrelated things haven't been on the fritz
Tags
compressor problems
Wish me luck Fodder4U General Turbo Discussions 12 03 Mar 2006 08:48 am
My luck KingKole02 Tech & Performance Forum 11 09 Dec 2004 01:53 pm
Bad Luck for Me....... Gear_Head General Turbo Discussions 20 22 Nov 2003 03:50 am
