PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
exhaust problem
Old 24 Apr 2004, 11:37 pm
paully paully is offline
Default exhaust problem
Dear all,
My '02 DreamCruiser has the BTG Duals installed, and is also sitting on some Eibach Pro-Kit Springs. Ever since the exhaust was installed, I have been dealing with a noise/bump/knock that comes from the exhaust pipe hitting the underbody at a yet to be determined location whenver I hit a bump. If anyone else has had the same problem and can suggest a way to fix it, I would surely appreciate it.
Old 25 Apr 2004, 08:27 am
ElectricBlueGT ElectricBlueGT is offline
paully,
This appears to be a pretty common problem when installing an aftermarket exhaust on a lowered PT. More than likely, the exhaust is hitting the rear axle whenever you hit a bump. Some people have been able to eliminate or significantly reduce the exhaust hitting the axle by going back and readjusting the exhaust to gain some clearance.
By the way, I had a similar type noise when I installed my front and rear swaybars on my stock height PT GT. I found out that the endlinks were not fully snug. Sounded like the exhaust was hitting the undercarriage. Once tightened, no more sounds.
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 25 Apr 2004, 09:26 am
Same here.
I've looked, fiddled, and pondered, no answer yet. [:I]
Old 25 Apr 2004, 10:46 am
CREWZIN CREWZIN is offline
Cured my knock by having the exhaust shop put an extra hanger around the area of the axle and pulling the exhaust another inch or so away from the top of the axle.
Old 25 Apr 2004, 06:11 pm
PTGT Redman PTGT Redman is offline
the pipe hits the rear axle. with new springs, there is increase suspension travel, in combo with decreased clearance will cause contact. whrn i uninstalled my bassani you vould see the contact point.
Homepage:
Old 25 Apr 2004, 08:58 pm
PTGT REDMAN/CREWZIN/QUICKSILVERDON/ELECTRICBLUEGT/
THANKS FOR THE INPUT REGARDING MY PROBLEM. GLAD TO KNOW THAT IT WAS SOMETHING INHERENT IN THE SET UP RATHER THAN SOMETHING I CAUSED WHEN I INSTALLED THE EXHAUST SYSTEM. CREWZIN, WILL TAKE YOUR SUGGESTION IN RAISING THE PIPES UP AN INCH OR SO. THANKS AGAIN/PAULLY
Old 25 Apr 2004, 10:17 pm
Jimbo Jimbo is offline
paully wecome to this forum.had the same problem cured it the same way Crewzin did
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 26 Apr 2004, 01:15 pm
KingKole02 KingKole02 is offline
You got my suggestion down pat.
KingKole02
SW Florida PT Cruisers
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
For cruiser pics go to:
http://ptcw.truckmoxie.com/mygallery.ten?id=3464
http://smg.photobucket.com/albums/v8...0in%20my%20PT/
For my personal page, visit
http://www.kingkole02.com
http://random-input.blogspot.com
http://www.ptcruiserweekly.com
www.jumpsometravel.com Travel Everywhere! - Owner
Old 27 Apr 2004, 10:23 pm
Hello all,
The local Midas store in my area opted to change the rubber hangers in the area of the rear axle to smaller ones, which also raised the exhaust pipes up from the axle and seem to have cured most of the knocks (about 90-95%). This quick fix costed all of $15.00 so I'll try it like this for now to see how things "hang". Thanks again all.
Paully
vB code is On
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Stage 1 with Dual exhaust Problem go-vair Turbo Performance 5 29 Jan 2004 10:17 pm
Need Exhaust Advise NkBkGt Exterior & Interior Styling 11 25 Aug 2003 10:36 pm
  Mortgages | Loans | Bad Credit Mortgages | Loans | Free Advertising
