intake leak
Old 16 Sep 2014, 11:08 pm
Default intake leak
I have a leak in the lower intake. I know it's not the water pump. I leak all the water out while the car is off. It has been overheating. I need to fix the leak. Can someone explain how to get to the lower intake?
Old 16 Sep 2014, 11:51 pm
Default Re: intake leak
It would be helpful if you could tell us what year, miles, and other information about your PT Cruiser.
Also a little history of what was happening to your PT Cruiser before it overheated and what you have done so far.
Old 17 Sep 2014, 08:06 am
Intake does not have coolant flowing through it. You may have a thermostat housing leaking. thats where the radiator cap is located.
Old 17 Sep 2014, 08:07 am
mine does..
..well water anyway
Old 17 Sep 2014, 08:11 am
Originally Posted by NitroPT View Post
mine does..
..well water anyway
You must be running water injection?
Old 17 Sep 2014, 08:12 am
maaaaybeee?
Old 17 Sep 2014, 08:48 am
Intake refers to air, not coolant.
What are you talking about?
Describe it.
Old 17 Sep 2014, 09:25 am
01 pt cruiser, 99k miles. I have checked all hoses from the radiator. Followed the leak to the housing to the water pump. I put stop leak in and didn't help. I let cool down and checked radiator and reservoir, both are empty. Filled back with water and it started leaking out without the car running. I've been told the pump and gasket will only leak if car is running. I believe it is the inlet hose, but don't know how to get to if.I have a picture, but don't know how to upload
Old 17 Sep 2014, 09:46 am
It's not the thermostat. It's something by the water pump, unless the thermostat is leaking down to the bottom hose.I don't have a leak at the top, it's on in the housing surrounding the pump
Old 17 Sep 2014, 09:49 am
Right above that area you show in your picture is the thermostat housing like Busted_PT has already said. I'd check there for signs of a cracked housing. It's only plastic.
Trade stock intake and new k&n drop in for cold air intake 03turbo Classifieds: For Sale/Trade 1 02 Feb 2013 08:43 pm
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
03 GT Intake hose and lower box with AirRaid Quick Intake Pt_SRT Classifieds: For Sale/Trade 2 16 Feb 2010 06:36 am
Plastic Intake Manifold cracked-boost leak! littleblueGT General Turbo Discussions 1 31 May 2007 03:25 pm
Upper/lower intake manifold gasket leak? im4gzs Tech & Performance Forum 14 03 Jan 2004 01:52 am
