Yes I'm overdue for an oil change, but didn't expect there to be NO OIL in my cruiser
Like Tree7Likes
  • 4 Post By myckee
  • 1 Post By Busted_PT
  • 1 Post By soonercruiser
  • 1 Post By rob342
Old 17 Sep 2014, 06:22 pm
Exclamation Yes I'm overdue for an oil change, but didn't expect there to be NO OIL in my cruiser
I'm not sure if this has anything to do with it, but I was driving two days after surgery on pain meds, which was STUPID, and while pulling out of a parking space went forward instead of backing out because I didn't see the concrete stops there. So I badonkadonked over two of them bad boys and freaked out all the way home wondering if I was going to break down. I never did, and still haven't. But my car has been idling funny like a tiny rumble noise I've never heard before (she's always run smooth) and I assumed it was because I'm a few, yes a FEW months past my oil change date. So I checked the oil today and there was NOTHING IN IT. Is that the norm? Or might I have a leak from doing the badonkadonk? PLEASE HELP! I'm a girl with no knowledge and my back's messed up so I can't get under it and look. Also no money for a mechanic. Any advice?
Old 17 Sep 2014, 06:46 pm
Default Re: Yes I'm overdue for an oil change, but didn't expect there to be NO OIL in my cru
You might have a leak from the "badonkadonk". You could try to pull the thinga-ma-jig to open the hood and remove the oil cap doohickey and pour a quart of oil in to see if it leaks out the bottom.
Old 17 Sep 2014, 07:05 pm
Maybe damaged the oil pan. It would be right in the way with an impact you described.
The good news if it is your can get it welded repaired on the the PT.
Old 17 Sep 2014, 07:55 pm
Please don't drive it again until you get this fixed.
Old 17 Sep 2014, 09:19 pm
If you can't get oil to show on the stick. Put some in till you do. Step back and see if the first one is running out. If none on the ground add till you see it on the stick at least before you go anywhere. Or you will be walking.
Old 17 Sep 2014, 09:43 pm
soonercruiser's Avatar
Unhappy Re: Yes I'm overdue for an oil change, but didn't expect there to be NO OIL in my cru
...for the syntax...
...for the original poster...
REALLY????
rob342 likes this.
Frank, aka SOONERCRUISER,
Old 17 Sep 2014, 11:02 pm
How many miles do you have on the car? On average how many miles do you drive every month?
Old 18 Sep 2014, 02:52 pm
i've run over a few of them concrete stops. driven off 12" curbs. plowed through snow plow piles. and ditches. etc.. makes some noise, but never hurt anything.. id guess you're just low on oil. do like BustedPT says. pour some more in there. see if any pours out.
Busted_PT likes this.
Old 22 Sep 2014, 11:29 pm
As others said, ADD OIL - NOW!
Put a large piece of cardboard underneath and look for oil spots on it.
heat and fan control ~ what to expect on 1 and 2 ? frances General PT Cruiser Discussions 7 22 Dec 2004 09:09 am
My Cruiser didn't win anything but I won the... Gary04GT General PT Cruiser Discussions 11 03 Nov 2003 02:05 am
What to expect as new owner DeeV-PT General PT Cruiser Discussions 8 19 Mar 2003 06:58 pm
