Headlights flickering
  • 1 Post By ptcruisersteve
Old 20 Sep 2014, 10:53 am
Default Headlights flickering
Hi I have a 05 cruiser with 135xxx miles. Have not had alot of problems with it but recently I have noticed my head lights kinda flicker when I put my foot on the brake. I dont think it would be an alternator problem cause the lights inside the car dont flicker at the same time. I have no check engine light on either. Any help would be great.
Old 20 Sep 2014, 11:59 am
Default Re: Headlights flickering
Sounds like a bad ground somewhere and lots of other threads talking about the same problem.
lights flickering
headlights flicker randomly
Lights flickering when brakes applied?
Flickering lights and fluctuating gauges needles...
check the rear tail lights for corrosion. it could be feeding back through the system.
88-98 chevy trucks had the same problem that what caused it
Old 20 Sep 2014, 12:11 pm
Have you checked your battery? Battery cables clean when you the battery cables off the battery? How often do you replace the battery on your PT Cruiser?
Flickering Lights thetunesguy Tech & Performance Forum 7 04 Jun 2014 07:05 pm
Flickering Headlights WEBCRUZN Tech & Performance Forum 4 17 Aug 2013 07:58 pm
Flickering Headlights 450HP Tech & Performance Forum 1 22 Oct 2012 07:55 am
H.I.D flickering blown05gt Tech & Performance Forum 0 17 Apr 2011 09:20 pm
Headlights flickering when brakes depressed? TripleJackInGA General PT Cruiser Discussions 3 12 Jul 2003 06:52 pm
