crankshaft sensor??
  • 1 Post By Busted_PT
Old 22 Sep 2014, 08:24 pm
Default crankshaft sensor??
replaced timing belt and water pump. now have crankshaft sensor error. replaced crankshaft sensor, still have error. 2006 pt non turbo 4 cyl, seems to run above 1000 rpm, rough idle below and sometimes dies. questions 1. is my timing mark possibly off? 2. could it be cam sensor? 3. just not sure what to do at this point?
Old 22 Sep 2014, 08:45 pm
Default Re: crankshaft sensor??
Have you checked your wiring. Seems like every so often I hear the wires were switched with another sensor after replacing timing belt or doing a head gasket repair.
Old 22 Sep 2014, 08:57 pm
I recommend you go back over your work rather hunting new problems. Also take a picture of the timing marks for future references such as these. Here are my pics for you to view and compare.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Old 22 Sep 2014, 10:06 pm
IMO I would replace the cam sensor with the original part double check everything and than precede to continue to look for the problem. My guess is the cam sensor may not have been bad?
Before retesting:
Clear the DTsC with a SCAN tool only!!!!!!!
Old 23 Sep 2014, 08:49 am
Before retesting:
He meant the crank sensor. But I agree, If you still have it,reinstall it. So not to add any new variables to the problem. Keep the new one for a spare. Need to rule out timing first.
Old 23 Sep 2014, 09:36 am
As did I . I just got off reading the other thread about DTC and it was a lose crank sensor bolt!
Makes for a good read?
Multiple codes and chugging problem
CrankShaft Sensor/CamShaft Sensor Questions PTMomma Tech & Performance Forum 8 12 Aug 2014 01:43 pm
crankshaft position sensor veses knock sensor BeagleDad Tech & Performance Forum 6 13 Feb 2012 06:10 pm
Crankshaft sensor replacement on an 06 snwlover79 Tech & Performance Forum 3 29 Nov 2011 04:22 pm
Where is the crankshaft sensor? barry8108 Tech & Performance Forum 2 08 Dec 2010 06:24 pm
HELP! Crankshaft pos sensor won't come out! reluctantlycrouched Tech & Performance Forum 0 09 Jul 2010 08:33 pm
