ABS and TRAC codes
Old 22 Sep 2014, 10:26 pm
Default ABS and TRAC codes
So, after power washing the engine compartment of my 2002, the ABS and TRAC codes have come on and stay on. I'm guessing one of the wheel rotation sensors is damaged or has crud on it?
j
Old 22 Sep 2014, 11:23 pm
Default Re: ABS and TRAC codes
That is a strong possibility.
I had a sensor go bad - first it would only act up when wet (just when you needed ABS), then it stayed bad.
I took it to mechanic since I didn't know how to find which one was the bad one - they did...
Old 23 Sep 2014, 08:57 am
Look over the wires going to each sensors and check the plug ends for corrosion and water. Also look for a notch with junk stuck in it.
Old 23 Sep 2014, 09:59 pm
are there sensors on the rear wheels too? or just the front?
Old 24 Sep 2014, 11:44 am
In 2002, all 4 wheels. (I believe later on they changed it).
Engine, ABS and Trac Lights on - Garage reorted no error codes AndyJay Tech & Performance Forum 15 03 Apr 2014 12:43 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
abs trac light donny General PT Cruiser Discussions 1 01 Jun 2010 08:33 am
Trac Off HLeyes Interior Accessories Forum 3 15 Sep 2008 05:52 pm
TRAC system shodobe Tech & Performance Forum 2 31 May 2005 07:58 am
