2003 manual transmission leak
Like Tree2Likes
  • 2 Post By rob342
Old 24 Sep 2014, 01:01 pm
Default 2003 manual transmission leak - non turbo
All,
The shop just called and said that my 2003 PT Cruiser's manual transmission is leaking at the "halfs". Down the middle of the transmission.
Just a couple of questions.
How do I tell if I have a G288 or T350 manual transmission?
How difficult is it for a DYI to remove and replace? I have a large jack stands and lots of tools...just never performed major surgery on the PT.
Where can I find good instructions on how to remove and replace.
In the Dallas / Ft Worth area, what company would you recommend I have rebuild my transmission?
Thanks for your help,
mims
Old 24 Sep 2014, 01:13 pm
Default Re: 2003 manual transmission leak
Maybe you don't need rebuild. Maybe just fix the leaks. If not a GT. I don't think they used g288.
Old 24 Sep 2014, 01:22 pm
like Busted says, depends if you have a turbo
IF you have a non turbo, you have a T350.
IF you have a turbo, ignore the rest of my info below
i resealed mine after i took it apart. it was not very difficult. use permatex anaerobic sealant.
if you're going to bother, i recommend skimming through my thread here:
i killed it.
you should also do the axle seals, and if you're taking it apart anyways, you may want to do the input bearing/seal cartridge assembly if it's greasy in the bellhousing.
Old 24 Sep 2014, 01:24 pm
here's a thread about removing the transmission. i wrote a step by step appx 3 posts down. i also included the confusing shop manual version.
5 Speed trans removal,, clutch replace info?
Old 25 Sep 2014, 07:46 am
Thank you Busted.
Old 25 Sep 2014, 08:50 am
Thank you Rob342!
My wife's car is s 2003 PT Cruiser, non-turbo, manual transmission limited model.
Resealing sounds fine. I like the idea.
I know I have the skill and the tools to remove the transmission then dropping it off at a repair shop. however, if I can understand how to replace the seals.... I am game.
Thanks for your extra effort in taking pictures and recording your steps.
Thanks again,
mims
Tags
pt 2001 manual with oil leak help cookie2001 Feedback and Support 10 24 May 2014 11:39 am
Transmission leak? Gabriella Tech & Performance Forum 1 02 Apr 2013 08:09 pm
Manual transmission 1gr8rubaz Tech & Performance Forum 0 05 Oct 2007 11:22 am
2003 CHRYSLER PT CRUISER GT-2.4 TURBO ** Manual Transmission ** (burlingame) $13900 skylight craigslist 0 14 Jul 2007 02:20 pm
Transmission leak macster Turbo Performance 17 25 Jan 2004 05:38 pm
