suspected intentional damage
Like Tree2Likes
  • 2 Post By rob342
Old 26 Sep 2014, 04:39 pm
Angry suspected intentional damage
hey guys, I got an 02 touring with 4 bang dual overhead. step daughters soon to be x-boyfriend got his hands on it for joy riding. was told where the car was and suggested to the head gasket being blown. after towing home I cranked it and it turns over but no start. I checked the timing belt for cam crank and both cams are turning. the engine sounds like it doesn't have compression while cranking. read codes of 0300 x 2, 0302, 0303 x 2, 0442,0455,0551 x 2. the cylinder misfires are what's concerning me. I'll deal with the "evap and power steering later". I've read on this as far back as 2012. my question before I start throwing money at this is, is there a sure fire way to test and determine that it "is" a blown head gasket ?
a way to rule out the wires, coil packs, plugs, injectors and so on and so forth ?thanks for any response, terry
Old 26 Sep 2014, 04:58 pm
Default Re: suspected intentional damage
check for fuel and spark.
check the plugs to see if they're coolant soaked.
check that all fluids look normal level and normal color.
i'd doubt headgasket is the issue if it won't start. a car with a bad headgasket will usually still start. last headgasket i blew i was shooting large amounts of coolant out the tailpipe.
if he's under 18, check with his parents about the repair bill before bothering with anything
UptownSport and boonie2 like this.
Old 26 Sep 2014, 05:12 pm
How many miles? He might have abused it enough to jump some teeth on the belt but not breaking it. Check the oil dipstick carefully to see if you see any antifreeze bubbles on the end with the oil.
Old 26 Sep 2014, 05:47 pm
There is a test that can be done to test for combustion gas in oil and coolant.
Clues are to be found by opening oil fill cap and looking for creamy froth, and opening radiator cap (when cool) to look at coolant for oil. A strange smell from exhaust from burning coolant is another clue.
Agree w/Rob, car usually starts and runs with blown headgasket.
Old 27 Sep 2014, 08:06 pm
UptownSport's Avatar
I;m not sure how one could get a timing belt to break on purpose (besides not changing it)
Old 27 Sep 2014, 08:23 pm
Says cams turning.
Clutch damage, + more?? unclemeat Turbo Performance 8 06 Aug 2014 12:29 pm
my PT's damage from the car accident xxcutetaraxx General PT Cruiser Discussions 5 13 Feb 2009 02:22 pm
Electrical damage???????????????? jinxmas General Turbo Discussions 5 06 Apr 2006 01:56 pm
