I have a socket stuck in crankshaft where pulley bolt is supposed to go
Like Tree16Likes
Closed Thread
  #21 (permalink)
Old 28 Sep 2014, 01:03 pm
Default Re: I have a socket stuck in crankshaft where pulley bolt is supposed to go
Originally Posted by KA9VQF View Post
The problem with that is the socket is in with the drive side out. You would have had to have the nut inside the socket before it was pushed into the end of the crankshaft.
My idea of threading the 1/4" square drive hole and using a long bolt might be the best {short of replacing the whole crank}
The picture doesn't look like it's drive side out...
Another thought - clean thoroughly with brake cleaner, etc. then put nuts in socket with epoxy - let epoxy harden, insert threaded rod or long bolt and pull the socket out.
  #22 (permalink)
Old 28 Sep 2014, 01:12 pm
LionPT's Avatar
  #23 (permalink)
Old 28 Sep 2014, 01:15 pm
  #24 (permalink)
Old 28 Sep 2014, 01:17 pm
I.D. socket position in relation to the crank. Ok well I guess that much is solved at least?
LionPT likes this.
  #25 (permalink)
Old 28 Sep 2014, 01:18 pm
Be careful not to spill the epoxy anywhere else!
quicksilverdon and JoeX like this.
  #26 (permalink)
Old 28 Sep 2014, 01:40 pm
Wow... my first post makes top 10 on the 48 hour hit parade!
I am watching this thread very closely and am extremely appreciative for every bodies input.
To make the one question 100% clear.... The socket is Drive side out (i.e. I can connect a 1/4" drive to it.
From what I have read so far, it seems that either the extractor or slide hammer are the best two choices ,albeit both scare me since I have no experience using either... this is probably not the ideal project to cut my teeth on That said, does one option have a higher potential of success than the other?
Can I ask that you send me a link to the specific brand/tool you would recommend for either the extractor or slide hammer....
Thanks again everybody for your input..... I will reply when I decide to bite the bullet and give it a shot...
  #27 (permalink)
Old 28 Sep 2014, 01:49 pm
Because of experience level I would actually try the bolt and nuts with an air impact wrench method mentioned.
Wish I could take the credit on that one. LOL
Because the socket is NOT hardened an impact wrench should work nicely and wriggle it free.
Harbor freight starting at about 50 bucks.
  #28 (permalink)
Old 28 Sep 2014, 02:20 pm
I believe that KA9VQF disqualified the nut & bold remedy with the following:
  #29 (permalink)
Old 28 Sep 2014, 02:35 pm
best of luck to you, but just "AAAAHAHAHAHAHAHHAHA!!" at this whole thread
did you ever hear of removing a pilot bearing with grease? you might try that. ie: fill the hole with grease and pound something in the hole. the hydraulic pressure would force it out. this works for dumb problems like this.
illustrated version:
  #30 (permalink)
Old 28 Sep 2014, 02:42 pm
No he was not looking carefully at the picture you posted close enough. A couple of us posted a little better edited version of your original picture. Not to mention you even cleared up which way the socket was even though you described it incorrectly.
The drive end is the ratchet side not the side that goes on the fastener BTW!
This is why I suggested based on your experience level and what you could acquire for the least amount of cost to you and ease of doing the task.
Maybe read my signature? Notice the blue?
rob there is so many reasons why this member should not try to do what is in that video...
Closed Thread
Crankshaft pulley Bashasup Tech & Performance Forum 11 28 Sep 2014 12:49 am
Stuck Crank Pulley - Bolt is Out tdf Tech & Performance Forum 6 31 Oct 2013 01:41 pm
Best Way to get crankshaft pulley bolt chitownpt Tech & Performance Forum 8 02 Aug 2012 07:03 pm
Crankshaft pulley bolt & engine rotation direction JenneK Tech & Performance Forum 6 30 Jun 2012 03:17 pm
Crankshaft pulley Bobwalker Tech & Performance Forum 3 09 May 2012 06:43 pm
