I have a socket stuck in crankshaft where pulley bolt is supposed to go
Like Tree16Likes
Closed Thread
Old 28 Sep 2014, 12:42 am
Question I have a socket stuck in crankshaft where pulley bolt is supposed to go
Just in case you know somebody that's done the same stupid thing I have... AND... know how they fixed it, please enlighten me....
Here's what happened:
1) I was trying to remove the crankshaft pulley with a three prong pulley remover and I needed an extension cos the middle bolt on the tool was too short.
2) I stuck a couple of 1/4" sockets in the center of the crank (assuming they'd be OK since they slid in easily)
3) Got the pulley off, and one of the sockets came out no problem.... The other socket is jammed deep in the crank, so tight, that all the methods attempted in #4 simply turn the crank. The end of the socket is about 1" from the outer end of the crankshaft (i.e. none of the thread inside the crankshaft can be seen)
4) I can get a 1/4" extension into the jammed socket and tried the following to methods to get it loose:
- attached 1/4"drill attachment and tried spinning it in both directions
- attached a 1/4 " extension to my air gun... Broke the extension
- attached a 1/4 " extension to a breaker bar and struck the bar with a hammer
in both clockwise & counter clockwise directions
btw... I'm a brand new member and this is my first post.... What a great first impression I must be making eh?
Please help
Old 28 Sep 2014, 01:05 am
Default Re: I have a socket stuck in crankshaft where pulley bolt is supposed to go
Welcome to the forum
Thanks for taking the time to fill out your profile!
Can you post a picture I can't seem to visualize your problem. I will admit my first thought was...........
I may half to go look at mine as I have only removed one on a 2.4 but several on 1.6 and the hubs are near the same.
Old 28 Sep 2014, 01:26 am
Wow what a fast response... I think I've attached the picture, it shows the crank with the socket stuck where the pulley bolt should go.
Old 28 Sep 2014, 01:42 am
Yup it is in there good and tight!
Old 28 Sep 2014, 03:04 am
I assume from the image that the opening of the socket is facing us. Please correct me if I am wrong.
What size is the outside diameter of the socket?
I would suggest being very careful and drill it out only cutting a little at a time with different size drills (metric,letter, and fraction size drills) or reamers until the wall of the socket is very thin. Use cutting fluid. You would have to be very careful and don't drill through the socket at the bottom of the socket. This way the socket can collapse if the walls are very thin when you turn it. If you were close by I would have stopped by and bring the drills and reamers to do the job.
Old 28 Sep 2014, 03:58 am
KA9VQF's Avatar
Is the engine out of the car?
If so you might be able to make a T handle hook out of steel and be able to pull it out. Or if you have a slide hammer you might be able to thread the 1/4 drive hole and screw in a bolt then attach it to your slide hammer and get it out.
Otherwise you might just have to get another crank.
The outside of the socket must have been small enough to easily go into the part that has no threads but the threads were much tighter and you have made a damn tight press fit of the socket. When you tightened the puller trying to get the harmonic balancer off it would have crushed the threads in, now they are working as barbs on a fishhook and not allowing the socket to be pulled out.
One size smaller socket and you might not have this problem but that's the real problem with hind sight does not help now.
Don't put off until tomorrow what you might be able to put off indefinitely.
Ignorance can be cured with knowledge, but Stupid is forever.
Old 28 Sep 2014, 07:20 am
Please help
I guess you know by now you should have asked sooner.... You need to make a longer rod to pull the harmonic balancer off. The kit I use is the same as yours.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 28 Sep 2014, 07:52 am
Handy_Cruiser's Avatar
You might try dry ice. It has to be DRY ICE. And remember to wear gloves or it will burn your fingers.
Pack just the socket with dry ice and let it evaporate. Then repeat. After that, try the methods in #4 again. The dry ice will make the socket very cold and may make it contract enough to get it out.
And to hold the craft from turning, try sticking some kind of bar in the front holes on the harmonic balancer. You might get it to catch on the casing somewhere. Just don't bust the casing. Another way is to get a very large pipe wrench to hold it. I have a 36-inch aluminum-handled stillson wrench that works great for this though it does leave some minor teeth marks on the outside of the pulley and of course I have to have room under the car to use it. I did this just a while back on a Mazda 6 engine.
Also if it is a cheap socket, you can likely drill it out thin and then use a small bunch to bend it down and loosen it up. But a good-quality hard steel socket is going to be very hard to drill and you may not be able to bend it until drilled out very thin.
One more thing is to ask some of the members here if they know how deep the threads in the crank go. On a Sebring I used to have, the harmonic ballancer bolt on its 2.4L engine stripped out. But I found the the threads went very deeper into the crank. I was able to go to a bolt/fastening shop and get a much longer grade-10 bolt that could reach the deeper threads. If the PT crank has deep threads like this, it may be possible to drill the socket completely out sacrificing the threads up to that point. But you will need to make very sue that there are deep threads and that there are enough of them.
If all threads are lost, it is also possible to get a die and put slightly bigger diameter threads into the crank. This may include drilling a bigger hole in the harmonic ballancer too. There are many pitfalls to that but I've seen it done in a diesel shop. I've also seen harmonic ballancers tack welded to cranks without threads. But that is VERY chancey since it can easily burn the crank seal and cause the crank to loose it's hardness.
Old 28 Sep 2014, 08:28 am
Can you wobble the socket side to side with the extension? Or just the extension. The slide hammer is a good idea to try if you can get a tight grip on the socket hole. Might have to do it a few times if it slips out. Use penetrating oil on the out side. Oh and welcome to the forum.
Old 28 Sep 2014, 08:50 am
Because a 1/4" extension is weak on the end, due to the cavity inside for the spring and ballbearing, I am not surprised it broke. I have done this a few times when trying to put lots of torque on them.
Perhaps you might try getting a hardened bolt and grinding down the end to 1/4'' and then trying to use it on your impact gun to spin it out? I am not sure if the bolt will get soft when you grind on it to shape it. Its just a thought. If the bolt breaks when its in the socket you may be even worse off..
I might be inclined to drill it out as others have mentioned.
Closed Thread
Crankshaft pulley Bashasup Tech & Performance Forum 11 28 Sep 2014 12:49 am
Stuck Crank Pulley - Bolt is Out tdf Tech & Performance Forum 6 31 Oct 2013 01:41 pm
Best Way to get crankshaft pulley bolt chitownpt Tech & Performance Forum 8 02 Aug 2012 07:03 pm
Crankshaft pulley bolt & engine rotation direction JenneK Tech & Performance Forum 6 30 Jun 2012 03:17 pm
Crankshaft pulley Bobwalker Tech & Performance Forum 3 09 May 2012 06:43 pm
