Help about ROUGH IDLE speed..
Old 28 Sep 2014, 01:04 am
ptptptpt's Avatar
Question Help about LOW IDLE speed??? 2001 PT
2001 PT Cruiser with 2.0L Engine..
My car has Idle below 500RPM. It never stops engine but stalls..
I read IAC issues and pull the PCV hose to see what happens, Idle turns to normal like 750RPM..
So I cleaned a bit IAC motor but nothing happens
What should I do what may be the problem???
Old 28 Sep 2014, 07:15 am
Default Re: Help about LOW IDLE speed??? 2001 PT
IAC controls air during idle via PCM. If its not working, cleaning will not make it work.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 28 Sep 2014, 10:37 am
How many miles on the PT Cruiser?
Was there any work done to it recently?
Is the idle smooth or rough?
Is the idle rpm the same cold and at normal operating temperature?
Old 28 Sep 2014, 10:41 am
Default Re: Help about ROUGH IDLE speed..
you may have cyklined missfire, you need a scan tool to ck ,
Old 28 Sep 2014, 10:48 am
This OP has a none US PT Cruiser. 2.0.
Although some similar suggestions can be made for generalized help the big problem is that fuel standards are very different outside the US. So this can dramatically effect how the engine will run. IMO it may be better for this OP to tell us what country he is in and have members from that country enter suggestion for the problem.
FREDI you should really first go start a "how do you do" thread and also attend to your profile.
Old 29 Sep 2014, 04:19 am
ptptptpt's Avatar
Oh, so I need to replace it to be sure? May aftermafket IAC will be useful? Mopar parts is a bit expensive at my country..
Btw I noticed IAC pulls itself when I tried if it works without screws after cleaning..
Old 29 Sep 2014, 04:26 am
ptptptpt's Avatar
Hi, my PT has 90.000 miles.. I have it about 3 years bought at 60.000 miles.. It has that problem since I got it!
Sorry its my bad, it has smooth but low idle!
It max 500 RPM.. But usually its low like 400RPM. Whrn I pull out the PCV hose it turns 750 RPM.
Old 29 Sep 2014, 04:35 am
ptptptpt's Avatar
Question Re: Help about ROUGH IDLE speed..
Hi there,
Sorry I am from Overseas, Turkey english is not my main language excuse for that.. I love American cars.. But here they are rare and sometimes parts and labor can be really expensive. The funny thing is I ask official chrysler dealer, "is it normal that low Idle? They have really no idea!:/
I search that forum and see that it can be related with that motor!! Its pity that Chrysler service have no idea about that.. There is no Error code or sign at my var
Btw part number is 4591611AA may be same with 2.4 PTs..
And here we have 95 octan fuel sometimes 97 which is at European standarts..
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
Rough idle when fan at high speed whitty1700 Tech & Performance Forum 8 19 May 2013 02:24 pm
Rough idle and high speed stumble / surge CCCruiser Tech & Performance Forum 6 18 Apr 2013 11:49 am
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
