My sad story of the instrument panel wiring hacked up
Like Tree3Likes
Old 28 Sep 2014, 08:56 pm
dalandon's Avatar
Angry My sad story of the instrument panel wiring hacked up
I just bought a 2007 pt touring , 2.4 non-turbo
Here's a little info on what the issue is, I had a couple of hard starts so i figured its the stater no big deal i'll call AAA if i cant start it and tow it home. It blew the #4 fuse in the TIPM "ignition switch" I pulled the fuse and found it was wound with a small amount of wire on the terminal legs of the fuse, oh great. I disassembled the TIPM and it appers good no fried components. I then removed the steering wheel cover around the switch assembly when behold, some one had ran a hot wire from the switch directly to the starter bypassing the relay itself and chopped up the harness in the process fixed it together with butt connectors and electrical tape. Its a miracle it even ran, so the harness has to be replaced most of the wires fell out of the butt connectors some at the plugs them self. Before I bought it I ran a carfax report no problems but it was owned by a rental/lease company for the first 30,000 miles then 2 others which show regular dealer services it has now 67,000 Im the 4th owner. When I was looking under the dash I found a gps tracking device and a remote starter disable I removed it and will contact the tracking agency. So due to the hacked up wiring Im forced to buy a replacement wiring harness OEM part #04795620AF, and installing it my self no problem with that Ive done it on other cars befor. It retails for a whopping price of $950 on up Would buying a salvaged harness be ok, or should I get $crewed by the dealer My wife and I loved this car so far its in excellent condition. If I get pictures Ill post them.
Old 28 Sep 2014, 09:17 pm
Handy_Cruiser's Avatar
Default Re: My sad story of the instrument panel wiring hacked up
There's some 2nd Gen PT's starting to show up in the salvage yards. You definitely want a used harness if you can get one. It should be under $50 if you pull it yourself. That is a whole lot cheaper than the dealer.
Also, it's very possible the hack job was done by technicians when the GPS tracker was installed. Sometimes they have to bypass a lot to get the kill function to work right. And those techs are often actually custom stereo guys. Too bad you can't just patch all back together correctly following a wiring diagram. That's what I would try first.
Old 28 Sep 2014, 09:31 pm
Used is as good as any if un damaged.
Old 28 Sep 2014, 10:12 pm
dalandon's Avatar
yes im sure its a stereo installer that did it, i found the wiring harness diagram but its 01-04
Old 29 Sep 2014, 06:44 am
LionPT's Avatar
This is for 2006 but should be the same up to 2010.
Old 29 Sep 2014, 09:47 am
dalandon's Avatar
Thumbs up Re: My sad story of the instrument panel wiring hacked up
Attachment 11708
Thanks this will help
Old 29 Sep 2014, 12:24 pm
dalandon's Avatar
Exclamation Re: My sad story of the instrument panel wiring hacked up
more pics;
basically it has to be torn down to a raw dash and the center console removed, so far the labor involved is about 5 hrs to tear down for the inexperienced, when I get the new harness it will probably take around 6-7 to put together, my son is also helping
Old 29 Sep 2014, 02:18 pm
Old 29 Sep 2014, 03:22 pm
dalandon's Avatar
On the plus side the former car dealer found the harness for $150 he is going to pay for it and the cruises are pretty simple to fix, so far........
Old 09 Oct 2014, 07:58 pm
Those are shrink tube butt connectors, They didn't even heat em up
Silver Bullet - 2001 PT Cruiser Limited, 5-Speed, 2.4 N/A, No mods yet just fixing her up slowly
Instrument panel bulbs BigBluePT General PT Cruiser Discussions 50 28 May 2017 01:07 pm
Instrument Panel Removal paulrosenthal Interior Accessories Forum 11 22 May 2011 02:39 pm
INSTRUMENT PANEL CHEVELINO Tech & Performance Forum 1 10 May 2011 08:19 pm
Instrument Panel Lighting bjagd02 General PT Cruiser Discussions 6 27 Mar 2011 07:43 pm
instrument panel azkruzn Interior Accessories Forum 2 06 Apr 2009 07:54 pm
