My '07 is eating heater cores!
Like Tree7Likes
Old 28 Sep 2014, 09:24 pm
Default My '07 is eating heater cores!
Hi everyone, I have yet another heater core question. I've scanned the threads, but haven't found an answer to this particular issue.
My '07 Touring has over 138k miles, and currently has its 5th cracked HC this year. I had the first one fixed in February, after the usual symptom of my windshield fogging up. Things were fine, I thought. I started smelling coolant shortly afterwards, but thought it might have been residual "burnoff" from the repair. I heard bubbling after turning off the ignition, again I didn't think much of it (but knew I'd have to get it checked out). In may, the vapors and the drips began, and I got another HC. At the end of June, the same symptoms started up and I got another one. End of July, that one cracked and I got another one. Beginning of this month, the vapors began again, and I was ready to drive the car off a cliff.
My local garage has replaced them all (& they've all been Chrysler parts) and says they've run tests to figure out what might be happening, but hasn't found a solution. They've sent me to a Chrysler dealer, having pretty much washed their hands of what's clearly a huge pain in the neck for them. The dealer is all set to "take a look", but I want them to communicate with the garage to find out what all was done before I start shelling out more money to be possibly told - again - "we have no idea what's wrong". Neither has been all that inclined to follow up, so I'm ready to go someplace new altogether.
I did see in one of the thread replies something about new HC's leaking and sometimes requiring a solder, but I wasn't sure about the details of that. The maintenance people all seem to be perplexed about this problem. What could be causing it? Is there anything I need to do once it's replaced? Is there something I need to tell the mechanics to look for? I'm at a loss and would appreciate any info at all.
Thanks!
Rhonda
Old 29 Sep 2014, 06:35 am
LionPT's Avatar
Default Re: My '07 is eating heater cores!
Honestly I have no idea either, 5 cores in a year...seems like it must be some kind of instillation problem.
Old 29 Sep 2014, 07:11 am
Check the the motor mounts are in good shape If they are shot. Could be the heater hoses being pulled on by the rocking of the motor. JMG
UptownSport and JoeX like this.
Old 29 Sep 2014, 09:41 pm
Thank you both for your feedback! I'm kinda hoping it's an installation issue, and that it'll just take someone else putting it in correctly to fix it! :-) I will also have my motor mounts checked, though. I so appreciate it and will keep you posted!
Rhonda
Old 29 Sep 2014, 10:17 pm
Thanks!
Rhonda
i wrote that. the problem i was describing is brand new heater cores leaking right from the factory, specifically the ones from murrays discount auto/o'reillys. i would not expect that to have anything to do with your car
Old 01 Oct 2014, 09:44 am
Thank you, rob342, I couldn't remember who said it! I read so many posts about HC, only a few details popped out here and there. Thanks for clarifying :-)
rob342 likes this.
Old 01 Oct 2014, 10:20 am
I'm wondering if your local garage has replaced the heater core. It is a huge PITA.
Did you request to see the old core to figure what was wrong? Surely after the second one that should have occurred to you or them to figure out what was going on.
How does coolant look? Open radiator cap and look for added goop (sealer) they may have thrown in.
Ray_Dockrey likes this.
Old 01 Oct 2014, 07:15 pm
I wonder if the garage really did replace the heater coil so many times or just keep adding sealer hoping to seal the leak.
Old 01 Oct 2014, 08:21 pm
Are you channeling me?
Old 01 Oct 2014, 09:00 pm
Oops! Too many hours at work and skipping words
Quicksilverdon I see you gave me the clue and I just spelled it out
eating thermostats ptc4boom Tech & Performance Forum 4 03 Jun 2014 12:27 pm
eating thermostats ptc4boom Tech & Performance Forum 4 03 Jun 2014 11:27 am
05 Cruiser eating gas cowboyinboxers Tech & Performance Forum 3 25 Feb 2014 04:33 pm
05 Pt eating gasoline!!! Help cathy2dep General PT Cruiser Discussions 16 09 Mar 2011 02:16 pm
