How to install and adjust timing belt tensioner
Old 29 Sep 2014, 02:50 am
Question How to install and adjust timing belt tensioner
I've been searching everywhere for details on how to properly install and adjust
the timing belt tensioner on a 2.4L PT cruiser.
Most discussions refer to a pin that should be installed on a new tensioner (not on mine).
Other discussions state to insert an allen key to relax tensioner during installation, then remove it once the belt is installed. I cannot see how this would be done.
I do not see any reference to the 13mm bolt on the front side, and a plate with a 1/4" square hole in it and an arrow pointing in a counter clockwise position. My guess is that this is what I use for the adjustment.... BUT I'd rather be certain.
Please help
Old 29 Sep 2014, 07:35 am
Default Re: How to install and adjust timing belt tensioner
Please help
No instructions in the box? Here is a pic of the line up of that type tensioner. You are looking ot the 1st design instructions HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Old 29 Sep 2014, 09:33 am
Thanks Busted... A picture tells a thousand words
Old 04 Oct 2014, 06:07 pm
Did the above pictured installation work out fine? I'm installing the exact tensioner but it will turn further clockwise as shown in my pic. I think it is wrong but worried the setting you pointed out earlier may be too loose - I don't have instructions as it was put in originally by the po. it also sems as if it should engage the aluminum tensioner bracket by going upward 3/16 inch or so. The Haynes isnt clear on what the correct tension should look like and this style isn't the typical it seems - help !
Old 04 Oct 2014, 06:27 pm
http://www.2carpros.com/forum/automo...87_pt_03_1.jpg
http://www.turbododge.com/forums/att...ng-timing2.jpg
Hope this helps.
Old 04 Oct 2014, 06:32 pm
nope but thanks that is the info I found in the Haynes -This must be the second revision type of tensioner I hear talk about ? Also I don't think the 220 ft lbs sounds right for a 13mm bolt
Old 04 Oct 2014, 06:53 pm
You are using the second design. just like the pics I posted. 01 and I believe 02 used the 1st design. Are you sure it's not Inch pounds. Line the tang as pictured.
Old 04 Oct 2014, 10:43 pm
So from rest then it would be turned maybe 3/4 of a turn to get where the original pic you recommend shows it.
I kept going until you see it in my pic. just a little more than that and it goes back to zero tension and you have to start over.
and yes you are right - after rereading it is 220 ''inch'' lbs - don't worry I didn't attempt to crank on it : )
timing belt tensioner neuner Tech & Performance Forum 3 08 Jul 2014 01:38 pm
Timing Belt Tensioner ? SteveG22 Tech & Performance Forum 11 19 Sep 2012 12:46 am
Timing belt tensioner? unioncreek Tech & Performance Forum 1 20 Jul 2012 12:00 pm
Timing belt tensioner slimjonesy General PT Cruiser Discussions 0 19 Mar 2011 06:35 pm
Timing Belt Tensioner 06ptbruiser Tech & Performance Forum 11 31 Dec 2010 10:39 am
