Time to replace the head gasket. Had a overheating problem from a leaking head gasket, warped or cracked head for a long time now. Just parked it and started looking into having the head milled and inspected for cracks. If I am going to go through all this work the last thing I want to do is put in a cheap head gasket. Any advice on a good brand name head gasket? I never tore this deep into a engine so any advice would be greatly appreciated.
Thank You, Chris |
![]() Quote:
How many miles you have on the PT Cruiser?
Have you replaced your timing belt? Water pump? |
Cam rock? It has 130k. Did the water pump and timing belt at 98k. Should I bother with new head bolts?
No. Follow manual's suggestion- Looked for stretched bolts by using a razor blade (straight edge) against threads and looking for stretch.
Years of Neon's no one's showed an actual pic of a stretched on- Since Chrysler changed from 10mm to 11mm in 1985. They did stretch before that- you could see it w/o a straight edge!!!
Useful Documents Useful How-To's Have an engine code? Sometimes this link is helpful Neon Bobble Strut ^^ Click |
![]() Quote:
The original question(s) addressed.
I do not believe that there are any head gaskets for a 2.4 that are better or fearful of using for a none performance built engine. IMO I would have the head first checked for surface straightness. If that is within the shops of choice allowance for surfacing than have the head pressure tested. At that point you can decide on having your head rebuilt or buy one already done? I do recommend just going for the replacing the head bolts. It is cheap insurance for piece of mind. |
Thread Tools | |
Display Modes | |
P0455 Major Evap Leak Major issue | h_wingman | Tech & Performance Forum | 16 | 27 May 2018 12:03 pm |
Major Issues--Help! | RobBurnsOH | Tech & Performance Forum | 2 | 03 Jun 2011 06:46 pm |
First major problem with my PT | heifetz17 | General PT Cruiser Discussions | 11 | 29 Sep 2010 10:36 pm |
How Do I Fix THIS? Major Scratches... | NewPTCruiserInPA | The Detail Shop | 12 | 02 Oct 2009 03:15 pm |
My First Major Repair | Johns Steel Blue | Tech & Performance Forum | 5 | 20 Feb 2009 09:13 pm |
