Is the timing belt broken?
  • 1 Post By boonie2
Old 01 Oct 2014, 11:20 am
Default Is the timing belt broken?
A friend's Cruiser died on the Interstate about 75 miles from home. The local mechanic says the timing belt is broken but didn't tell her how he knows that.
I can think of a couple of ways to determine if the timing belt is in fact broken but what is the easiest way?
Also, is it or is it not an interference engine?
Old 01 Oct 2014, 11:28 am
cruserdad1976's Avatar
Default Re: Is the timing belt broken?
NON INTERFERANCE
the most it can do is the valves can hit each other verry seldone happens
how many miles???--this is Key
you can pull the cover and see of the cam gears are turning but i dont know of any other way wioth out getting inside the motor
Old 01 Oct 2014, 12:08 pm
Pull the cam sensor and see if the magnet is turning.
2016 Kia Soul Plus Black
Old 01 Oct 2014, 12:55 pm
Yes, 2 8mm bolts and lay it as side. Crank it over look in the hole and see if it turns.
Old 01 Oct 2014, 02:58 pm
boonie2's Avatar
{QUICK SIDE OF THE ROAD CHECK }listen to the RPMs when your cranking the engine over , faster than normal , its the belt , or , take a flat head screw driver slip in into the seam at the timming belt cover, [on top] and twist it open enough to see the belt , then have someone turn the engine over
cruserdad1976 likes this.
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Broken timing belt/broken valves DreamCar Tech & Performance Forum 17 13 Mar 2012 01:35 pm
Broken Timing Belt. Cartmansnuts General PT Cruiser Discussions 11 11 Feb 2012 02:39 pm
Broken timing belt mantonmark General PT Cruiser Discussions 4 12 Aug 2011 05:47 pm
No start after broken timing belt mojojo Tech & Performance Forum 13 12 Aug 2011 12:25 pm
