Still won't start!!!
Old 01 Oct 2014, 08:16 pm
Default Still won't start!!!
Ok guys I am trying to figure out a problem I am having. 06 pt with 110000 miles on it. Took it to guy who changed timing belt, bent valves. He called me and told me the bcm was bad so I bought one and he changed it. Got halfway home and everything just died. No hazards , no power of any kind. Went and bought a new battery and cleaned all the connections and now I have power. Problem is the car won't start. It will turn over and I've got spark, fuel is good. Buddy of mine told me it might be the bcm he put in. Any help would be appreciated. Also no error codes are showing up.
Old 01 Oct 2014, 08:52 pm
Default Re: Still won't start!!!
Canbus system is not easy to figure out. I would suggest you really should take it to the dealer and have them hook it up to their system and they can easily see whats working and whats not working on the Canbus system.
If you have the time and want to start with the basics I would start with the all the sensors. Make sure all the sensors are tighten down and all the wires are connected firmly to them.
Old 02 Oct 2014, 11:13 am
cruserdad1976's Avatar
how did you bend the valvues??? the PT is non interferance and Im guessing the BCM is a PCM
Do you have spart at the coil??? does it have fule in the fuel rail???
if so id have to say the timing is some how not right
Old 02 Oct 2014, 04:42 pm
I have fuel and I do have spark at the coil. I think they were bent because the timing belt didn't break but the teeth came of the belt. I thought they wouldn't be bent either but that's what the guy told me. I had a buddy come over last night and couldn't pull any codes at all. I am having a hell of a time with this. It just cranks and cranks but no start. Could it be a camshaft sensor or a crankshaft sensor? Is there a way to test.
Old 02 Oct 2014, 04:51 pm
LionPT's Avatar
Unplug them one @ a time & plug them back in and try to start car after each...be careful the Crankshaft Sensor is tough to get to...don't break it.
Have you checked the Starter..??
Old 02 Oct 2014, 04:58 pm
Starter is good according to a buddy of mine. Will the car start if one of the sensors is unplugged?
Old 02 Oct 2014, 05:06 pm
LionPT's Avatar
Don't try to start it with them unplugged...unplug 1 check the plug & plug it back in & try to start car...than unplug the other one check plug & plug it back in & try to start car. If you unplug both & replug you won't know which one gave you the problem...it might just be a loose connection, the car will start with a bad Camshaft Sensor, but run rough...the car won't start with a bad Crankshaft Sensor.
If the car broke down on the way home after the repaires, why haven't you taken it back..??
Old 02 Oct 2014, 05:10 pm
The guy won't return my calls. He hasn't gotten any money from me either. I really don't want him touching it anyways. Where exactly is the crankshaft sensor at.
Old 02 Oct 2014, 05:13 pm
LionPT's Avatar
Above the starter...unhook the battery before you unplug anything.
Here is a video for the Camshaft Sensor...
Old 02 Oct 2014, 05:25 pm
That's gonna be a tough one to get to.
05 pt will not start dtw05pt Tech & Performance Forum 13 28 May 2013 11:33 pm
car won't start jinky Tech & Performance Forum 6 28 Dec 2012 05:09 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
What a way to start the day!! Knotsobright1 General PT Cruiser Discussions 7 06 Oct 2009 12:00 am
Ran out of gas and now won't start Gracie512 Tech & Performance Forum 28 09 Jul 2009 10:15 pm
