Timing tensioner bracket question
Old 02 Oct 2014, 06:37 pm
Default Timing tensioner bracket question
Hey Cruisers, I have my mounts off because of the po's lack of tightening skills and about to put the belt back on but noticed the tensioner mounting hole is oblonged ( because of the aforementioned issue - and the upper t-srut was completely broken away ). Is there supposed to be a spacer in this hole or is this normally oblonged? I just spent a few days fishing out a broken bottom mount bolt and the one that went into this tensioner hole came out bent. I haven't done a PT belt before so not sure if I'm looking at a normal part or something damaged. I did note that the left bolt hole in the casting has a spacer and thus wondered if one belongs here as well tks Bart
Old 02 Oct 2014, 06:55 pm
Default Re: Timing tensioner bracket question
From the black paint on the inside surface edges of the hole. I would say that it was made that way.
Engine Rebuild - Timing Belt Tensioner Question tdf Tech & Performance Forum 5 15 Dec 2013 10:32 pm
Timing belt tensioner help faysCruzn Feedback and Support 8 16 Oct 2013 08:36 am
timing belt tensioner question!!!! HELP!! slimjonesy General PT Cruiser Discussions 5 08 Apr 2011 08:59 am
Timing belt tensioner question - 04 PT 2.4L matt Tech & Performance Forum 0 29 Mar 2011 05:12 pm
Timing Belt Tensioner 06ptbruiser Tech & Performance Forum 11 31 Dec 2010 10:39 am
