Lost All Brake Lights and Need Help Troubleshooting
Like Tree3Likes
Old 02 Oct 2014, 06:58 pm
Default Lost All Brake Lights and Need Help Troubleshooting
I have a 02 Cruiser with 2.4 and an automatic and it has 161K miles on it.
Recently I was told by another motorist that I have no brake lights at all. When I got home I check the fuse under the hood and it was blown. Replaced the fuse and it worked for a little while, but blew again on my way to work. Changed the fuse again before leaving work and it worked fine while parked, but as I was driving down the road it blew the first time I hit the brakes. Got home and pulled the car into the garage to start digging into this. I changed out the fuse again and now everything works fine and I cannot get it to blow the fuse.
So here is where I am at:
1. My brake light fuse will blow while driving losing both left and right along with the center high light. No brake lights at all. All other lights work fine (Parking and turn signals).
2. With the brake pedal removed from the bracket (lights staying on) I have pulled the interior panels looking and shaking down the wires around the brake switch along with all the wires in all three tail lights and behind the left rear quarter panel. Lights remain on and no shorts.
3. No condensation in any of the light sockets.
4. Pulled both rear brake light bulbs and no obvious signs of a bad socket along with shaking and twisting all the wires around the sockets. No shorts and light are still on (remember I pulled the brake switch from the mount bracket so the lights should stay on).
5. I have a trailer wiring adapter and shook the crap our of those wires with no issues.
No here is the weird part, I can pull the brake fuse and I have no problems with the shift lock solenoid and I can put it in gear with no power to the lights. Guessing the shift lock solenoid goes through the brake light switch, but does not need brake light power to work.
What am I missing at this point? I hate to drive it again until I get this figured out or I wish it would keep popping fuses making it a ton easier to trace down the short
Open to suggestions on what else to do.
Thanks in advance,
Greg
Old 02 Oct 2014, 10:10 pm
Default Re: Lost All Brake Lights and Need Help Troubleshooting
There was another forum that mentioned something about wires behind the rear quarter panel forcing the harness to rub against the metal edge and over time the car's vibration helped to wear to a short circuit. You might want to double check that area.
Old 03 Oct 2014, 06:30 am
Will do. Saturday is calling for rain os that will be a good day in the garage tracing the wires from the fuse block to the ground afters the lights.
Old 03 Oct 2014, 07:26 am
Sometimes those trailer adapters fry internally and could very well be causing your fuse to blow even with no signs. Unless you are pulling a trailer regularly, I would disconnect that box and see what happens. If no more blown fuses then you have found the reason. If not, look deeper.
Old 03 Oct 2014, 12:07 pm
If I cannot find anything after inspecting all the wires, that is what I will do
Thx
Old 09 Oct 2014, 07:07 pm
Was your car ever in an accident? If so, wiring harness could be pinched...
Old 10 Oct 2014, 08:31 am
No accident in its past.
I have just left it in the garage waiting for me to trace the wires front to back and see if I can find anything. Right now all is fine. May drive it around a little today and see if it pops the fuse while all the panels covering the wiring are off.
Old 10 Oct 2014, 04:35 pm
Just had a thought....
Try braking with the lights on and see if that pops a fuse...
Old 12 Oct 2014, 06:32 pm
Good suggestion, but still worked without popping the fuse and infact the last time it popped I was driving home from work (3:30pm).
I have disconnected the trailer harness and put everything else back together and will drive it around and see what happens.
Old 15 Oct 2014, 07:49 pm
Not claiming victor yet, but drove it the last two days with no issues. All I have done was disconnected the trailering wires and put it all back together. I did notice that at least one of the trailer wire splices had the metal exposed a tad and I suppose that could have been touching the body and causing the short.
Will continue to monitor before I claim AOK.
Brake lights wont work, 3rd brake does Dill General PT Cruiser Discussions 17 03 Oct 2016 04:34 pm
TAIL LIGHTS ND BRAKE LIGHTS NOT WORKING mccloud12 Tech & Performance Forum 7 12 Jun 2014 06:21 pm
lost all lights on dash, guitarman Tech & Performance Forum 4 17 Apr 2013 04:24 pm
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
Why do my tail lights and dashboard lights only go on when I brake? bodykits Exterior Accessories Forum 1 16 May 2009 07:28 am
