Square Hole tensioner help
Old 05 Oct 2014, 01:52 pm
Default Square Hole tensioner help
Hi, I have the tensioner with the 1/4 drive. I'm setting it up with just the info I have been finding and have been given so far by my Cruiser friends here.
Here is where I am at. from rest position I turned the 1/4 drive of the pulley cam in the counter clockwise direction about 3/4 of a turn to this position (see pic). I lined the spring to the center of the inner moving tab.
Is this correct? there doesn't seem to be any printed instructions on this type so if anyone has it in their pile of paperwork perhaps you can post it here under this thread for me and other curious Cruisers
Old 05 Oct 2014, 02:27 pm
Default Re: Square Hole tensioner help
That looks good to me. Rotate the marks and recheck. If still looks like the alignment is good. Crank it up and see if you have smooth acceleration.
Old 05 Oct 2014, 02:40 pm
marks are spot on after several spins but the tensioner backed off a bit so i have to bring it up again. I was wondering if there is any specific marks that have to correspond. I'm making assumptions and that isn't cool in a belt job.
Old 05 Oct 2014, 03:02 pm
Your are just checking that the marks are on and that the tensioner is still in proper adjustment. Which you said It did not do.
Old 05 Oct 2014, 03:06 pm
LionPT's Avatar
I know from your other thread that you replaced the timing belt, but did you replace the tensioner pulley also..?? This might be your problem with why you can't get it set right.
Old 05 Oct 2014, 04:11 pm
cam sprockets were rubbing the upper cover when I bought it and it was running rough (no codes ) Kid said it had a belt/pump job a year ago which it does look to jive with that info. The upper torque strut was broke and not even connected and stressed the mid mount loosening it up and damaging its bolts - putting pressure on the upper cover causing the rub and squeal. I decided during the repair to check the marks bc it was running rough and sure enough it was off a tooth. A slight defect in the belt made me change it out. This is my last step but had no info on the way to set the tensioner. I'm familiar with the VW set up and they have an arrow and notch to gauge the proper position, I though this would have something similar. I have set this to your instructions and rotated the engine three complete times and have reset the tensioner again each time but its not as if it moved very much. Just trying to imitate your picture. I think its fine but this is my first PT and don't want to get it wrong
Old 05 Oct 2014, 04:24 pm
This picture shows where it comes to rest after a few spins, is this ok?
Old 05 Oct 2014, 05:16 pm
I would like to see a little more consistency but if it will remain in between the two outer points. You should be ok. Other opinions welcome here.
Hole In Dash? randyincctx General PT Cruiser Discussions 52 15 Sep 2017 03:10 pm
EGR hole or no hole gwairbrush General PT Cruiser Discussions 4 12 Aug 2014 04:11 pm
The Pot Hole Won! coondog Classifieds: Want To Buy 4 02 Jul 2010 01:39 am
Exterior Square Feet? BeachBum General PT Cruiser Discussions 0 11 Feb 2008 02:31 pm
Square hood portholes? njsteve Exterior Accessories Forum 13 26 Jan 2005 11:06 am
