Is this right
Like Tree2Likes
  • 1 Post By NitroPT
  • 1 Post By scatgo1
Old 05 Oct 2014, 08:17 pm
Default Is this right
I am going to be putting my cylinder head back on as soon as I get it back from the shop And this is the info i got for the head bolts but it is for a 06 pt and I have a 02. Can I use these torque spes for my car?
First: All to 34 Nm (25 ft. lbs.)
Second: All to 82 Nm (60 ft. lbs.)
Third: All to 82 Nm (60 ft. lbs.)
CAUTION: Do not use a torque wrench for the Fourth step.
Fourth: Turn all bolts an additional 1/4 Turn
Old 05 Oct 2014, 08:28 pm
Default Re: Is this right
If that is what the book says. Then it's right. All models use the same.
Old 05 Oct 2014, 08:44 pm
According to my 2001-2003 Haynes manual it's 25, 50, 50, additional 1/4 turn AND there's a particular tightening sequence of the bolts. If you don't have that sequence, it's like this...
10..6...2...3...7
9....5...1...4...8
Old 05 Oct 2014, 08:48 pm
You may want to get a set of new head bolts
Old 05 Oct 2014, 08:58 pm
http://www.autozone.com/autozone/rep...96b43f802e2afd
Just found this. Autozone has a great repair section for thous of us who can never find our shop manual when we need it the most. Thanks for taking the time to help out this lost cause.
Peace
3rcruiser likes this.
Old 05 Oct 2014, 09:11 pm
NitroPT,
Are all bolts used to hold components to the engine block softer than the engine block itself?
Old 05 Oct 2014, 11:27 pm
Originally Posted by ptcruisersteve View Post
NitroPT,
That is an interesting question. There is no straight answer. This really has more to do with the casting,sleeves,thread inserts,etc. Generally it is only important when assembling a Performance built engine that will be operated at high RPM.
I would sometimes Time Sert all the threads on a high horsepower engine in the critical area's.
Then there is the question of durometer test a block or head ? Not many do that.
Recently I was given engineering specification for a block and head to come up with a solution to sealing the factory head. I had to request a complete durometer testing first before I suggested idea's. I wish I could say more but at this time it is under design for a racing team. But I will only say that gasoline is not used but the green handle at the stations.
