Grinding noise from engine
Like Tree2Likes
Old 07 Oct 2014, 04:45 am
Default Grinding noise from engine
Hi all
I hope someone can help me. I have recently cleaned the intake manifold with intake/carb cleaner. The car sounded fine and ran fine after the treatment. I then drove about 60 miles with it, on the freeway. When I arrived home I noticed a grinding like noise from the engine that was not there before (almost sounds like when the brake pads are done and it's metal on metal). It only happens at idle. Sometimes it goes away for a while and then returns. It's not super loud, but it's definitely new and something wrong, in my opinion. The noise is consistent in nature. Does not sound like it's coming from a pully.
Two nights ago (same day I did the cleaning treatment) I stood at idle for a while trying to find the source of the noise. I then revved the engine slightly (perhaps to about 3000rpm) and heard a knocking noise, but I heard it only ONCE. Thereafter it ran normally again. However, right after hearing the knocking noise the car spat out a huge ball of smoke. And as I said, the car ran fine after that. There are no driveability issues, the power and response is what it usually is and there are no other noises from the engine. The knocking has not been heard ever since.
Yesterday the grinding noise was gone at startup and for quite some time. I then heard it again later in the day and it went away. Today I didn't hear it at all.
I trust that if I don't hear it anymore the issue is solved, but I am concerned it might not be. Does anyone have any idea what could have caused it? Specially with the knocking noise and smoke that one single time and then the engine running fine immediately thereafter.
I forgot to mention, I have a 2002 model 2.0L petrol.
Old 07 Oct 2014, 08:12 am
Default Re: Grinding noise from engine
What brand intake/carb cleaner did you use?
Old 07 Oct 2014, 08:14 am
I live in South Africa so I am not sure if you would know the brand. I used Wynn's Carb cleaner. Don't know if that helps.
Old 07 Oct 2014, 08:27 am
What year, how many miles and has it been worked on lately?
Old 07 Oct 2014, 08:46 am
Ha ha. Sorry I should have mentioned... it is a 2002 model 2.0L Petrol. It has only about 30 000 miles on the clock. It has not really been worked on recently. I changed the coolant about a month ago. Besides that, it's only the intake and throttle body cleaning treatment that I did this weekend.
Old 07 Oct 2014, 10:28 am
FYI
You should never use a carburetor cleaner in a system that is fuel injected.
Wynn's and other brands have specific cleaners for carburetor and another for fuel injection.
Sensors and other parts can be damaged with some carburetor cleaner used in a fuel injection system.
Always read the label there are some that can be used in both systems. Just be sure you get the correct cleaner for the fuel system you have.
All PT Cruisers are fuel injected.
Old 09 Oct 2014, 01:28 am
Originally Posted by NitroPT View Post
FYI
I have read somewhere that this could be used, but I guess I must have been misinformed. I hope the engine will be fine though. I haven't heard that grinding noise again and it has been 5 days since.
Old 10 Nov 2014, 06:17 pm
I am hearing a annoying grinding noise from by 2002 Turbo which sounds like it is coming from behind and below the glove box; my P.T has 175,000 miles on it, and I have it in the shop today getting a compression test and TB inspection done. It almost sounds like some type of bearing going out, and I am thinking water pump. It sounds louder when the engine is cold, but still persists after heating up. Time to dump my P.T., or stick with it ? The garage just called and the engine compression is 175-175-170-165. It is a "grinding" noise.
Old 10 Nov 2014, 06:25 pm
LionPT's Avatar
I'm pretty sure you wouldn't hear the water pump grind...it could be the alternator.
Old 10 Nov 2014, 07:14 pm
maybe a slightly bent or sticky valve that keeps rotateing around from good to bad
, and now it drops a bit of oil thruogh the motor hence smoke,
keep an eye on oil consumption,
Tags
engine noise, intake, knocking, smoke
Grinding noise bogaz Wheels, Tires, Suspension 1 22 Jul 2012 03:20 pm
Grinding noise while slowing down, whirring noise while speeding up thedarkcanuck Tech & Performance Forum 5 27 Nov 2011 10:15 am
Grinding noise. PtOnAir Tech & Performance Forum 6 10 Jan 2011 09:40 am
Another Grinding Noise... bjagd02 Wheels, Tires, Suspension 3 01 Nov 2010 09:01 am
Grinding noise SmittysGold Tech & Performance Forum 21 20 Oct 2008 07:25 am
