Spark plug question
Old 10 Oct 2014, 06:12 pm
Crid's Avatar
Default Spark plug question
Hi all just changed the plugs in my 06 n/a and they were quite oily is that normal? And they were all white execpt one. I'll post a pick. Tell me what you think.
2006 Cruiser, Non-Turbo, 19 inch Konig Trouble rims on 225/35/19 Ironman Imove tires, Airaid CAI, E3 Plugs, msd super conductor 8.5 mm wires, Freedon Design Strut Tower Brace, Glow Shift Pillar gauges, EBC Slotted Rotors with EBC Green Stuff Ceramic Fiber Core Pads, Lowerd on Tien springs, Full Custom Kenwood Excelon sound system with 1 12" JL Audio W0, 8000k Blue hids up top and aftermarket OEM Fogs with white 8000k in bumper. Ipcw Bermuda black true led taillights with tinted reverse lights.
Old 10 Oct 2014, 06:20 pm
Default Re: Spark plug question
The insulator tip and center electrode seems to be OK. You might need some new well seals to stop the oil getting to where it shouldn't be.
boonie2 likes this.
Old 10 Oct 2014, 06:39 pm
boonie2's Avatar
Def. the well seals , mine looked exactly the same.. when i first bought the car i changed out the plugs and found maybe an inch of oil had leaked in
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 10 Oct 2014, 07:15 pm
You have more top electrode wear on the 2nd from top and the bottom one than the other 2...
Old 10 Oct 2014, 07:29 pm
Crid's Avatar
Ok I'll order some well seals do you need to remove the head to change em?
Old 10 Oct 2014, 07:30 pm
Crid's Avatar
Is electrode wear a bad thing?
Old 10 Oct 2014, 08:32 pm
KA9VQF's Avatar
Naturally you would like it best if the electrode wear was even on all cylinders. It depends a lot on how many miles were on the engine or at least the particular set of spark plugs you have removed from your engine.
From what I can see in your picture the center two look to be cleaner than the others the three upper ones look to be more burned away than the bottom one.
As I recall you only recently bought this Cruiser. I don't suppose you know how many miles these plugs have on them. It will be interesting to see what the plugs look like when they need to be changed next time.
And no you don't have to remove the head to change the seals. You will have to remove the valve cover though. If any of the spark plug tubes have come loose you will need some rags and red locktite too. If the tubes are tight you can just put the seals in the valve cover and reinstall it.
There is a lot of stuff that has to come off first though like the intake manifold. Time consuming but not all that hard. You might want to get a new set of intake seals too. When I had mine off I decided the seals were alright and just put it all back together.
Don't put off until tomorrow what you might be able to put off indefinitely.
Ignorance can be cured with knowledge, but Stupid is forever.
Old 10 Oct 2014, 09:11 pm
Crid's Avatar
And no you don't have to remove the head to change the seals. You will have to remove the valve cover though. If any of the spark plug tubes have come loose you will need so rags and red locktite too. If the tubes are tight you can just put the seals in the valve cover and reinstall it.
I have had the cruiser for 5 years now and these plugs have around 75k on them.
And wen u say spark plug tubes u mean the sleeve they sit down in?
Old 10 Oct 2014, 10:09 pm
"spark plug well seals" in the diagram Crewzin posted above.
Old 10 Oct 2014, 10:30 pm
KA9VQF's Avatar
Yes the spark plug wells are what I meant that may well be the correct name for them. The seals go in the valve cover and once the tubes are properly seated in the head the seal fits on the top of the tubes.
Even if none of the spark plug wells are loose in the head you will still have to remove the valve cover to put in the new seals.
2002 PT Spark Plug Question tipsymcstagger Tech & Performance Forum 9 15 Sep 2012 08:44 pm
Coil and spark plug wire question? Cyclone35 Tech & Performance Forum 5 26 Mar 2011 07:58 pm
Another spark plug question :D CruseadorPT Tech & Performance Forum 3 10 Aug 2009 10:00 pm
spark plug question greasemonkeyjmj Tech & Performance Forum 10 07 Feb 2009 05:46 pm
Question on spark plug gapping... wyzard Tech & Performance Forum 3 07 May 2005 07:36 am
