ABS and TRAC codes
Like Tree8Likes
Old 11 Oct 2014, 08:18 pm
Default ABS and TRAC codes
Okay. I took the 2002 PT Cruiser to my mechanic and he ran his SNAPON tool and told me rear right. I replaced it. Still have the problem. Any suggestions?
regards,
james
Old 11 Oct 2014, 08:36 pm
Default Re: ABS and TRAC codes
regards,
james
Did I miss an explination of the problem?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 11 Oct 2014, 10:43 pm
yep. replaced the rear right sensor and no change. is there some where else I should be looking?
Old 12 Oct 2014, 12:06 am
It just gets funnier all the time
Old 12 Oct 2014, 12:34 am
cruserdad1976's Avatar
ok so why are we even talking about here a little info might be helpfull
JoeX likes this.
Old 12 Oct 2014, 10:32 am
Its funny how a little bit of wine will make me think I gave all the details and very clearly at that...so, that being said...my mechanics scan tool indicated that the right rear wheel speed sensor is bad. Both the ABS and TRAC lights are on. I replaced the sensor and the ABS and TRAC lights are still on. Another car I own, a Honda, after I replaced the sensor, the errors cleared themselves. Does the PT Cruiser clear these errors on its own or do I still have a problem in the wiring between the new sensor connection and the computer?
regards,
james
Old 12 Oct 2014, 10:46 am
I would recommend that your friend clear the DTC;s and go from there.
For all other PT Cruiser owners and members here. I really recommend if you are going to be doing work on your own PT invest in a diagnostic scan tool. Most forums and internet information requires that you continue active use of a diagnostic scanning tool to be effective at trouble shooting and solving issues that are ECU/PCM warned.
If you are going to waste a lot of favors from friends using their Diagnostic scanning tools and spend money by guess replacing parts you might do it the better way buy a scan tool and at least have a better chance at finding the problem with a one time purchase of a single part?
Harbor freight has this scan tool that is within budget of most everybody.
OBD II & CAN Professional Scan Tool
Cen-Tech - Item#60694
Old 12 Oct 2014, 11:02 am
Actually, I paid my mechanic for his diagnosis. That being said, will the scan tool you provided a link for, give the details as to which wheel speed sensor was bad? Some, many, scan tools will only give you the engine error codes and nothing more.
James
Old 12 Oct 2014, 11:46 am
James
If you paid than your "mechanic" should have cleared the DTC's after the replacement of parts.
Your PCM should be re-set as I suggested. Although the PCM will self clear at times on TRAC or ABC I have seen them take days and several engine PCM cycles before they do.
Chrysler PCM/ECU should not really be compared to other ECUs on other make vehicles.
If you intend to do further advanced ABS as well OBDII and CANbus viewing than you would need a scan tool like this:
OBD II & CAN Scan Tool with ABS
Cen-Tech - Item#60794
Old 12 Oct 2014, 12:17 pm
What NitroPT says about buying OBD II Scanner
When the engine light first came on on my PT Cruiser I went to Harbor Freight soon after and got my OBD II Scan tool at 50% off. Harbor Freight has good discount sales and if you sign up for their emails you can also get free items with your discounted purchases.
ABS and TRAC codes jdlmodelt Tech & Performance Forum 4 24 Sep 2014 11:44 am
Engine, ABS and Trac Lights on - Garage reorted no error codes AndyJay Tech & Performance Forum 15 03 Apr 2014 12:43 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
Trac Off HLeyes Interior Accessories Forum 3 15 Sep 2008 05:52 pm
TRAC system shodobe Tech & Performance Forum 2 31 May 2005 07:58 am
