2002 PT Cruiser Won't Start
Old 13 Oct 2014, 04:16 pm
Default 2002 PT Cruiser Won't Start
I have a 2002 Cruiser with 204,000 miles. Timing belt replaced recently, new IAC Valve, new Camshaft position sensor, and all vacuum hoses intact and engine won't start. It'll turn over but won't catch. Codes said vacuum leak IAC. Replaced valve but still nothing. Camshaft is turning so it's not timing belt and battery is good. Any help will be greatly appreciated.
Old 13 Oct 2014, 04:33 pm
Default Re: 2002 PT Cruiser Won't Start
Fuel and spark. Your 02 should have a Schrader (?) valve at the end of the fuel line to check for correct fuel pressure.
Old 13 Oct 2014, 06:26 pm
Did you replace the new IAC Valve first?
Then the new Camshaft position sensor?
Is the new IAC Valve from the dealer?
Is the new Camshaft position sensor an aftermarket brand?
2002 pt cruiser wont start ale_05 Welcome New PT Cruiser Members 2 13 May 2014 09:30 pm
2002 Pt cruiser won't start after turning it off Wfdowns General PT Cruiser Discussions 6 25 Dec 2013 08:24 am
My 2002 Cruiser won't start Racechaser Tech & Performance Forum 11 12 Aug 2012 12:42 am
2002 PT CRUISER WON'T START -98k MsLeah General PT Cruiser Discussions 9 12 Jun 2010 08:19 pm
2002 PT Cruiser will not start!!! WTF!!! thinkinboutit General PT Cruiser Discussions 3 16 Feb 2010 10:53 pm
