Timing Problems
Old 14 Oct 2014, 10:00 am
Default Timing Problems
I have 2001 PT 2.4L. My problem started with a water pump. After taking the motor apart and replacing the water pump and replaceing everything from belts to motor mounts. I reassemble the motor and I had no fire. I set the crank pulley with diamond mark with the mark on the block. I set the cams with the timing marks. The bolts that hold back timing cover were visible in the lower lobes of the cam pulleys. I have the motor apart now.
Question? Is there any way to determine if the exhaust and intake stroke on the cams are right? Is one side set to an exhaust strokce and the other side on intake stroke.
They both should not be set to exhaust or intake in the same stroke but should be opposite of each other? I need some one help on solving my issues. I got to get this car back on the road today, HELP
Old 14 Oct 2014, 02:20 pm
Default Re: Timing Problems
waiting for introduction...... Where are you from, tell us about your PT Its easier to get answers that way...
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 15 Oct 2014, 09:59 am
UptownSport's Avatar
You need to use a straight edge through cam bolt centers, then check time marks.
You can't really mess up gears unless you put them on with "2.0" facing out.
Example on a 2.0 (notice the "2.0", which, if you see, would indicate an issue)
Here's the 'easy' check for general cam position, courtesy Booger Racing"
Good luck!!!!
Please Help!! Timing belt replaced and having engine problems tylines69 Tech & Performance Forum 9 20 Aug 2013 10:05 pm
Timing belt installation problems fgssr General PT Cruiser Discussions 7 16 Aug 2013 08:31 pm
Having problems with timing belt sleepy General Turbo Discussions 20 14 May 2013 08:59 pm
Timing problems Rickydunit Tech & Performance Forum 9 07 May 2013 03:44 am
