2005 Pt Turbo Conv.
Old 15 Oct 2014, 03:25 pm
Question 2005 Pt Turbo Conv.
I love my PT. The other day I was getting on the highway and my check engine light came on. The car didn't want to accelerate up to the highway speed. Had it checked and the code was P2074. Changed the MAP sensor and it is still on throwing that same code.. Any help would be great. I cant stand having that light on..
Old 15 Oct 2014, 03:35 pm
Default Re: 2005 Pt Turbo Conv.
PT problems read this FIRST
chances are it was not the MAP sensor
Old 15 Oct 2014, 03:37 pm
Does car still run lousy?
MAP sensor is only one potential cause...
P2074 Chrysler Manifold Pressure/Throttle Position Correlation- High Flow/Vacuum Leak OBDII Engine Light Trouble Code | Engine-Codes.com
Old 15 Oct 2014, 03:55 pm
The problem with posting "what the code" (which anyone can find on the internet) is that you eliminate the need to perform "proper" use of a Diagnostic scanning tool in the OBDII Diagnostic port.
Anyone can post what the definition of the codes are but you need to go beyond what the displayed DTC is and actually do some Diagnostic testing.
This is a big reason why the key dance is not very useful along with simply just having a DTC cleared. It does not correct the condition that caused the DTC and in most case like this thread reported the DTC returns.
Old 15 Oct 2014, 04:14 pm
It runs fine it just don't accelerate like it did. And if I give it a lot of gas its like it jerks. And when I am going highway speed and I let off the gas there is a nice jerk there as well
Old 15 Oct 2014, 04:17 pm
I did have it tested with the OBDll.
Old 15 Oct 2014, 05:18 pm
You do not test accessing the OBDII diagnostic connector you use it to help diagnosis PCM control engine issues.
Apparently it appears that all you had done was scan for DTCs and clear them nothing more?
Old 15 Oct 2014, 08:19 pm
soonercruiser's Avatar
Cool Re: 2005 Pt Turbo Conv.
Originally Posted by quicksilverdon View Post
THIS ^^^^^ is the question.
You said still showing the code.
But, was it still hesitating??
Frank, aka SOONERCRUISER,
Old 16 Oct 2014, 10:14 am
Yes it is still hesitating. I am a female and I have been around cars all my life. I have changed transmissions, brakes and even valce cover gasket. But this is my first PT and turbo car. I just dont know all the technical stuff. Just figured I'd ask you guys.
Old 16 Oct 2014, 10:41 am
PM sent
Tune Up for 2005 GT Turbo conv. Laranapr Turbo Performance 18 26 Jul 2014 10:31 pm
2005 PT Conv - OIL INFO junebug657 Tech & Performance Forum 1 04 Jul 2012 01:00 pm
Analyze this Carfax Please? 2005 Conv. GT 36,000 miles tony17112acst General PT Cruiser Discussions 9 19 Aug 2010 10:00 am
2005 PT Cruiser Conv. jasonbgriffin PT Cruiser Convertible Forum 3 16 Aug 2010 09:26 pm
Did I make the right deal? 2005 GT Conv tpsfoto PT Cruiser Convertible Forum 17 09 Nov 2007 12:04 am
