Air only blows out dash vents..2007 PT
Old 15 Oct 2014, 03:36 pm
Default Air only blows out dash vents..2007 PT
The air is only blowing out of the dash vent no matter where I turn the swich too.. I used to be hard to turn from defrost to floor...Any suggestions would be appreciated..Thanks
Old 15 Oct 2014, 03:39 pm
Default Re: Air only blows out dash vents..2007 PT
Remove center dash parts and AC/Heater control panel and start from there
Old 15 Oct 2014, 03:46 pm
LionPT's Avatar
It sounds like the cable was kinked...now something probably broke.
Your going to have to take off the center console to find/fix the problem.
To remove yours...there is 1 phillips head screws in each of the center vents (you'll need to shine a flashlight to see them at the bottom), then just slowly pry off the cover till you can unhook both the clock & the power window switches...from there the cover will pop off enough for you to see what's wrong...if not, remove the vent controls & remove console completely.
PT Dash vents not allowing air flow barhopping Interior Accessories Forum 11 23 Apr 2015 12:58 pm
Air Only Blows Out Floor & Side Vents Nick Tech & Performance Forum 3 02 May 2014 08:05 pm
05 Pt Center Dash Bezel Vents RichP Classifieds: Want To Buy 6 04 Apr 2013 07:08 pm
Question about replacement air vents on a 2007 skullvankrush Interior Accessories Forum 10 04 Jun 2010 02:44 pm
Air Vents Stuck on Dash. stabbal Interior Accessories Forum 1 16 Jan 2009 05:51 pm
