bought new scan tool, ABS communication trouble
Old 17 Oct 2014, 11:56 am
Default bought new scan tool, ABS communication trouble
Bought the Cen-Tech 60794 per someone's recommendation on here so I could diagnose problems I'm having with the ABS system. It fails to connect to the ABS system. Has anyone on here had this problem
Old 17 Oct 2014, 12:14 pm
Default Re: bought new scan tool, ABS communication trouble
Are you OBDII or CANbus?
If your PT is pre 06 it is OBDII in which case there should be no issue communicating with the Scan tool. You may need to contact the tech number in your instruction manual and talk with a Cen-Tech rep because you may have a faulty unit. Make sure if you talk to them that note the name of the tech you talk to. Harbor freight is careful about diagnostic tools being returned or exchanged.
If your PT is 06 and newer than it is CANbus in which I have had trouble with Chrysler model communicating with the ABC scan tool. After a few attempts it would finally communicate? I have had no one been able to tell me why this happens? If after many failed attempts you may also need to contact Cen-Tech.
Keep in mind it is a several step process to get the ABS information unlike checking the DTC and readiness area of the engines operating systems.
For technical questions, please call 1-888-866-5797.
Old 17 Oct 2014, 01:00 pm
Mine is a 2002 PT Cruiser. Brand new Cen-Tech with the ABS functionality.
Old 17 Oct 2014, 01:05 pm
First check for DTC and also that everything is green in the OBD II Readiness Monitors. Clear and re-set everything and than drive a short distance (about 20-30 miles) and recheck to make sure everything is green and clear.
Then try to access the ABS information.
You may be having output information conflicts?
If you you get “LINKING ERROR” than you need to cal the tech line as I suggested in the previous response.
Old 17 Oct 2014, 01:13 pm
waiting on tech support phone call. #14 in line.
it is the linking error that i get
Old 17 Oct 2014, 01:15 pm
auh..I see. Ok well please post what they say!
Old 17 Oct 2014, 01:37 pm
trying email support now.
no communication from dtc port goernhrd General PT Cruiser Discussions 1 09 May 2012 04:05 pm
OBD Scan tool compatibility AndrewJ Tech & Performance Forum 0 23 Feb 2012 06:17 am
Lost Communication With ecm/pcm oronzo Tech & Performance Forum 7 20 Aug 2011 07:40 pm
OBD Compact Reader Scan Tool Question sinbad2050 General PT Cruiser Discussions 3 26 Mar 2011 01:10 am
Scan Gauge II ucantcme Classifieds: For Sale/Trade 0 14 Oct 2008 07:49 pm
