a/c heater problems!
Old 18 Oct 2014, 09:52 am
Default a/c heater problems!
New to site. Have a 2004, my a/c went out and was going to wait till spring to fix. My problem is when I turn control for where to have air/heat ,hard to turn and will not let it go to windshield. But also when I turn on fan to any speed, the a/c engages ( the compressor is locked up) and car dies. Should the compressor be engaging with heat on? Thanks
Old 18 Oct 2014, 09:55 am
Default Re: a/c heater problems!
If you aim control at windshield, that's defrost, and yes, defrost turns on the A/C.
Old 18 Oct 2014, 01:21 pm
If the control is hard to turn, STOP! The control cable is binding and further use may break the control or panel.
I recommend to pull the dash cover and find the binding problem first.
You may need to unplug the AC clutch connector until you repair your AC system so the compressor is not engaged.
A/C problems after heater core replacement Cruiserlover7 Tech & Performance Forum 2 03 Jun 2014 04:21 pm
2006 Heater problems yenciny General PT Cruiser Discussions 3 07 Nov 2013 03:52 am
heater blower problems tracker General PT Cruiser Discussions 3 22 Oct 2012 04:27 pm
o2 heater circuit problems Aristo99 General Turbo Discussions 2 04 Oct 2012 07:12 pm
............Heater Problems.............. fatboypt Tech & Performance Forum 1 16 Jan 2012 10:34 pm
