battery question
Old 18 Oct 2014, 11:30 am
Default battery question
We took a week trip and while gone I hooked up the battery to charge for the car in storage . The charger was on 'float charge' . When I got back I could smell the sulferic gas. Question is........if water is way down then .putting water in and charging is of no use, the battery is shot. Correct?
Old 18 Oct 2014, 01:12 pm
Default Re: battery question
Using a volt meter check voltage.
Replenish the fluid and recheck voltage.
You may need to have the battery load tested.
IMO based on your description, you cooked you battery!
Old 18 Oct 2014, 09:09 pm
Sorry but I agree with Nitro. I think you cooked it. You can fill it and try but don't bet on it. It might work ok now but I would bet first deep freeze of winter and you will be S.O.L.
Old 18 Oct 2014, 09:29 pm
Agree, but nothing to lose by trying - you must use distilled water - get it at a supermarket for steam irons.
Old 20 Oct 2014, 10:30 am
Thanks guys, it is shot only 10 volts. Why would the battery have gotten cooked when it was on float charge?
Old 20 Oct 2014, 10:45 am
are you sure it's a float charger and not a trickle charger? a float charger will automatically shut off when the battery is fully charged. a trickle charger won't.
2016 Kia Soul Plus Black
Old 20 Oct 2014, 02:43 pm
cruserdad1976's Avatar
most NEWER chargers will shut off when it si fully charged
Battery fit question. RedLimited Tech & Performance Forum 10 31 Jan 2014 04:13 am
Installing amp and battery question Cruiszr Sound and Security Forum 8 05 Jul 2012 05:30 pm
A why & a How question about battery blucruzer General PT Cruiser Discussions 29 16 Sep 2010 06:19 pm
optima battery question Kcruiser78 Tech & Performance Forum 6 25 Nov 2007 03:59 pm
