I am About to Lose My mind!!!!!!!!!
Like Tree4Likes
Old 18 Oct 2014, 06:29 pm
Default I am About to Lose My mind!!!!!!!!!
Old 18 Oct 2014, 06:36 pm
Default Re: I am About to Lose My mind!!!!!!!!!
Originally Posted by scatgo1 View Post
\\Try again,nothing is showing or working!
Old 18 Oct 2014, 06:40 pm
Trying to post some pics of the problem and that ain't even working for me right now. Belt tensioner wont even touch the timing belt to tighin it up! I have the first style tensioner setup. Looks like I have the right belt!
Old 18 Oct 2014, 06:42 pm
LionPT's Avatar
Xxxx Photo by scatgo | Photobucket
EDIT: Changed Link To Photos
Old 18 Oct 2014, 06:49 pm
Originally Posted by LionPT View Post
If you can see that pic that is the second style tensioner. I have the old style and at max out position it wont put enough tension on the belt. Do you think the second style tensioner will fix thi problem?
Old 18 Oct 2014, 06:54 pm
As you might be able to see if the pic is showing lots of slack with tensioner set to max.
Old 18 Oct 2014, 07:06 pm
I might be wrong about this, but I don't think your routing the belt around the correct way.
Busted_PT likes this.
Old 18 Oct 2014, 07:14 pm
LionPT's Avatar
Looks like your right to me
scatgo1 likes this.
Old 18 Oct 2014, 07:30 pm
Can you guys tell if the diameter of the tensioner wheel in my pic is smaller than the one in the pics you guys posted? Like I said I have the old style setup.
Old 18 Oct 2014, 07:39 pm
The thing is, if the belt is routed the correct way, it shouldn't matter if you have the old or new style tensioner. They should both work no matter if one is slightly bigger than the other. I ran the old style for 5 or 6 years before I had enough mileage to change the timing belt and the old style tensioner worked well. I only went to the new style because it came with the "kit" that had all the parts I needed from RockAuto.
SO, take the belt off, re-route it according to my picture and you'll see that it all fits together perfectly.
jdlmodelt and scatgo1 like this.
someone needs to lose some extra poundage bhunt41 Tech & Performance Forum 27 14 Nov 2011 08:06 pm
About to ?*#@ing lose it! (Adding freon to A/C) Cruising Mike General PT Cruiser Discussions 41 30 Oct 2010 11:33 pm
My car has a mind of its own! Mortza General PT Cruiser Discussions 5 08 Apr 2009 08:36 am
Non Factory Stereo -- Do you lose the in dash display? Aurock Sound and Security Forum 5 06 Jan 2009 10:50 pm
Lose that weight Mel K Tech & Performance Forum 6 02 Nov 2003 08:41 pm
