Transmission drain pan
Old 21 Oct 2014, 12:26 pm
dalandon's Avatar
Question Transmission drain pan
Is it weird that my transmission pan doesn't have a drain plug? The others i've seen do.
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Old 21 Oct 2014, 01:02 pm
Ray_Dockrey's Avatar
Default Re: Transmission drain pan
Most cars and trucks don't. People either add the drain plug or change out the pan for an aftermarket one that does. You must have just got lucky with prior vehicles. I have never owned a vehicle that had one.
Old 21 Oct 2014, 02:54 pm
cruserdad1976's Avatar
yep same here well kinda never had a car with one my 04 Chevy Silverado with the Duramax and Allison do i just added a Dorman to my PT ir was like $26 at Oriely I think Rock Auto is cheaper i did it when i changed the tranny fluid and filter which is a pain to get to stay in the hole
Old 21 Oct 2014, 08:59 pm
Next you'll be looking for zerk fittings....
Transmission stuck in 1st gear 2007 PT Cruiser Touring (Automatic transmission) ProdigyMan Tech & Performance Forum 7 19 Jan 2014 02:51 pm
Automatic Transmission Pan With Drain Plug Matt42 Tech & Performance Forum 3 18 Aug 2010 11:31 pm
Transmission Pan with Drain Bolt - They Exist ! lmmegt Tech & Performance Forum 8 02 Oct 2009 10:51 am
Transmission drain and fill issue!!! 2002ptcruiserwoody723 Tech & Performance Forum 10 01 Oct 2009 09:02 am
Help! How to drain and refill automatic transmission? crooner44 Tech & Performance Forum 7 11 Jun 2009 01:42 pm
