Rear Speakers Not Working
Old 22 Oct 2014, 11:22 am
Default Rear Speakers Not Working
I have a 2002 Cruiser with the AM/FM/Cassette/CD stereo. I just happened to notice that my left rear speaker isn't working at all and the right rear speaker is only working at about half its normal volume. (?)
Where should I start inspecting ? Check the speakers first or would it be the stereo itself ? I'm thinking it's not the speakers as one still works, only at a reduced volume.
Thanks,
Mark.
Old 22 Oct 2014, 11:26 am
LionPT's Avatar
Default Re: Rear Speakers Not Working
Originally Posted by markroach View Post
I have a 2002 Cruiser with the AM/FM/Cassette/CD stereo. I just happened to notice that my left rear speaker isn't working at all and the right rear speaker isn't working at all. (?)
Check the speakers themselves...pull the door panels, find a working speaker, unplug it & move it from door to door.
Old 22 Oct 2014, 11:29 am
Thanks,
Mark.
Isn't there a front/rear balance adjustment? Look there first.
Old 22 Oct 2014, 11:52 am
Handy_Cruiser's Avatar
Thanks,
Mark.
There's a chance the speakers are bad. The left rear speaker was bad in my 2001 limited. The back speakers on the 2001 and 2002 are different than later models. They are usually painted black and the magnets are narrower but thicker. But the later speakers will work and appear to be the same quality. I replaced my bad one with one out of a 2003. All I've seen will say "premium" on them.
The best way to check if it is the speaker or something else is to use another speaker or mutlimeter. It's always possible that you have a wiring or stereo head issue. But I've seen many a speaker die in older cars.
Old 22 Oct 2014, 01:25 pm
Thanks guys. That's how I fully discovered the problem was by playing with the F/R and L/R controls.
Found it odd that one rear speaker was only capable of about half its normal volume and the other was completely non-functional. Sorry, I originally typed that both rear speakers were not functioning. The left rear does not work at all and the right rear works only at about half volume to what it should be.
Mark.
Old 22 Oct 2014, 04:49 pm
Just got home from work and had a closer inspection (listen). The right rear speaker is at about half the volume it should be and if I listen carefully, with the volume turned up to maximum, I can just hear the left rear speaker.
So, the speakers ARE functioning to some extent - as opposed to no sound at all. Will damaged speakers diminish in sound like this, or is this something happening with the stereo unit itself ?
Thanks,
Mark.
Old 22 Oct 2014, 05:23 pm
I could be either. A weak ground (audio return wire) might cause a working but not performing speaker. So could a bad amp in the stereo head. And of course, a bad speaker can do the same.
Without putting eyes on the situation, I also suggest to do what is easy and cheap first. Try the weak speaker on the other side and see if it does the same thing. And if you have any other speaker, try that. You can even cut up a cheap pair of earphones and tie in that way to see if you get sound.
Old 22 Oct 2014, 08:48 pm
Thanks for the ideas - I'll give them a go this week-end.
Is there a trick to getting the rear trim panel off ? Isn't obvious what holds it on, and I have an aversion to breaking things ....
Mark.
Old 23 Oct 2014, 04:12 pm
UPDATE ....
I had a couple good rear chrysler speakers I had scavenged from my old Sebring, so I hooked those up to the two rear terminals. Both speaker provide decent volume now, but they sound like an AM radio with hardly any bass response at all (they sounded good in my Sebring).
This stereo doesn't have a separate amp for the rear speakers somewhere does it ? My Sebring had a separate factory amp under the rear package tray.
So, with this info in hand, any thoughts ? Still sound maybe like a bad stereo itself ?
Thanks,
Mark.
Old 25 Oct 2014, 03:56 pm
UPDATE II ....
Friend of mine loaned me a good stereo unit to try. I removed mine and installed his. No difference in sound, so it's not the stereo itself.
Still scratching my head ....
Mark.
Rear speakers shomy87 Sound and Security Forum 61 08 Aug 2012 05:42 pm
Speakers stoped working Wakinglife213 Sound and Security Forum 8 05 Jul 2009 07:44 pm
WTB rear speakers Franksredpt Classifieds: Want To Buy 1 12 Nov 2004 12:16 pm
Rear Speakers silver03 Exterior & Interior Styling 4 28 Dec 2003 08:35 pm
Rear Speakers cruisergeo Sound and Security Forum 14 27 Apr 2003 02:38 pm
