No spare key
Old 24 Oct 2014, 02:00 am
Default No spare key
Lost all keys, how can i get key code and make a new key
Old 24 Oct 2014, 06:27 am
LionPT's Avatar
Default Re: No spare key
The dealer can get your code with your VIN number, but it won't be cheap as the key needs to be programed.
BTW: if your ignition has ever been replaced it won't matter.
Old 24 Oct 2014, 08:51 am
And you can read your VIN # on dash thru the windshield on driver's side.
And for Pete's sake, have 2 or more keys made....
Old 24 Oct 2014, 10:34 am
if the key was black and thin it won't cost much. if it was light brown and thicker it's a transponder key and won't be cheap.
2016 Kia Soul Plus Black
Old 24 Oct 2014, 11:40 am
KA9VQF's Avatar
If you have one of the original keys you can buy a blank with the chip in the plastic part of the key and have anyone with a key cutter grind the right bumps on it.
Then you can clone that new key/s using instructions that are available on the net. Here is what I found
Instructions
1
Bring the replacement sentry key to a hardware store or dealership. Have it cut to match the original valid sentry keys.
2
Place the first valid key into the PT Cruiser's ignition and turn to the ON position for a minimum of three seconds and a maximum of 15 seconds. Turn ignition switch off until it is in the LOCK position and remove the key.
3
Within 15 seconds, insert the second valid key and turn the ignition to the ON position. Wait ten seconds or until a chime sounds and the vehicle security light begins to flash. Turn the ignition off until it is in the LOCK position and remove the key.
4
Within 60 seconds, insert the new blank sentry key into the ignition switch and turn it to the ON position. Wait 10 seconds or until you hear a single chime and the vehicle security light stops flashing. Look for the indicator light on the dashboard. If it turns on for three seconds and then turns off, the key has been successfully programed.
I've done this with our '05 Neon and it worked fine but I both of the original keys for that car. When we got our PT Cruiser we only got one key. I bought a new key and key fob off eBay and tried to clone it with just the one key I have and it did not work. I was able to program the key fob with just the one key fob we got though.
The dealer wants $130.00 just to program the second key now. I'm looking for a locksmith that has the proper equipment to do this for me hopefully for less money.
Don't put off until tomorrow what you might be able to put off indefinitely.
Ignorance can be cured with knowledge, but Stupid is forever.
spare key soyomb General PT Cruiser Discussions 14 04 May 2018 12:14 am
Full size spare and the Spare Cage azguath Wheels, Tires, Suspension 4 18 May 2011 05:00 pm
Spare Key??? ptguy69 Sound and Security Forum 1 23 May 2010 03:08 pm
Spare Tire Ramzm Wheels, Tires, Suspension 5 24 Jan 2010 07:49 am
grrr...spare..... midnight01 Wheels, Tires, Suspension 7 16 Jun 2009 12:27 pm
