engine swap 2001 pt limited 5 speed
Old 27 Oct 2014, 12:15 pm
Default engine swap 2001 pt limited 5 speed
Not sure if this was asked before thinking of doing a swap from a pt gt in to my 2001 . I've been searching for a 5 speed gt can't find so I figured I'd make one . Any thoughts thanks
Old 27 Oct 2014, 12:26 pm
Handy_Cruiser's Avatar
Default Re: engine swap 2001 pt limited 5 speed
That's going to likely be problematic and very hard if possible.
The 5-speed tranny used in the 2001 is not the same as the "Getrag tranny used in the later GT. Also, GT's that have 5-speeds have different PCM's than GT's with automatics. And if the GT was originally an automatic, even the speedometer cluster is different.
There lots of info on the web about doing this. But it's going to be hard. Here's a good thread as a primer.
Need help to swap to a manual transmission
After that, put "pt cruiser transmission swap" into Google and see what comes up.
Also, right now GT PT's are fairly cheap. The most economical plan would likely be to sell what you have now and buy a GT with a manual tranny already in it.
2001 Engine swap mastifffreak Tech & Performance Forum 19 18 Feb 2014 10:35 am
Engine swap 2001 to 2007 boerter Tech & Performance Forum 7 16 Feb 2014 11:08 am
Can I swap a 2001 w/egr engine for a 2002 engine w/o egr? cas0918 General PT Cruiser Discussions 5 15 Feb 2013 11:58 pm
2001 Engine and parts swap out. anneslimo Tech & Performance Forum 11 18 Jan 2013 05:38 pm
Can I do this engine swap 2003 to 2001 jrr344 Tech & Performance Forum 10 11 Mar 2012 02:12 pm
