Error codes P1684/P1603/P0714/P0218
Old 27 Oct 2014, 06:40 pm
Default Error codes P1684/P1603/P0714/P0218
05 PT CRUISER 144k mi, base model automatic.
Days start, check oil, good, tranny fluid good, power steering little low, engine coolant reservoir dry. No action taken at the time
Driving down road started hearing a weird knocking, was a deeper noise, not high squeal whining or anything. Felt like car was a little off on power so thought maybe one of the cylinders was misfiring. Was watching temp gauge all day to see if it started overheating nothing.
Then a few more miles i noticed that i was at 3k rpm just to cruiser about 40mph. Kept getting worse, noticed it wasn't shifting higher than second.
So decided to head straight home, didn't make it that far, felt like it was going to die, check engine light came on. Pulled into AutoZone parking lot and there it went dead.
Got those codes, thought maybe i'm lucky and the engine coolant might fix the problem >> i'm not an expert on how transmissions/engines work so really had no idea but code said tranny overheat, coolant low, figured two must be related.
Wife showed up, added fluid went to drive home, nope. Kept it at 1500rmp all the way home any higher and it started acting funny, wouldn't go higher than second and the speedo stopped working.
Pulled Error codes P1684/P1603/P0714/P0218
Reset codes by discon battery, drove about 4 miles to test, engine light came back on speedo not working whole time. Would shift through all (4) i think gears no problem, still had the feint knocking.
Mechanic said it's possible that the tranny wont shift becuase speedo is out, but tranny started having probs before the speedometer started to have them. Speedometer sensor on the transmission? Could it overheating have burned it out? or it going out cause tranny to start acting weird?
Lost at this point.
Old 27 Oct 2014, 06:58 pm
Default Re: Error codes P1684/P1603/P0714/P0218
Last two codes
P0714 - Transmission Fluid Temperature Sensor Circuit Intermittent Symptom can be - Engine Light ON (or Service Engine Soon Warning Light)
- Possible shifting problems
P0218 Transmission Over Temperature
Old 27 Oct 2014, 07:21 pm
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles.
P1603: PCM Internal Dual-Port Communication Failure.
Possible Causes Setting Condition:
Fused ignition switch output is missing (off-start-run circuit)
PCM has an internal failure
Old 27 Oct 2014, 07:27 pm
Did you change your transmission oil lately?
Old 28 Oct 2014, 07:08 am
Yes,
Had it changed at the beginning of the year.
Old 28 Oct 2014, 08:06 am
When you changed the transmission oil filter was there any metal shavings at the bottom of the transmission pan?
Old 28 Oct 2014, 04:28 pm
Unsure, i had my mechanic knock it out along with timing belt, water pump, and fuel injectors
Old 28 Oct 2014, 11:50 pm
What transmission oil did your mechanic put in it?
Old 29 Oct 2014, 04:13 pm
I couldn't tell ya, invoice was handwritten didn't specify type.
Old 29 Oct 2014, 04:24 pm
cruserdad1976's Avatar
well the PT requires ATF 4 sounds like a tranny issue so how low was the coolent
Error Code P1684 hawk18 Tech & Performance Forum 7 13 Jul 2015 10:55 am
P1684 Error Code-How do I fix it? StreetCruiserUK Tech & Performance Forum 22 24 Sep 2011 07:50 am
codes p1684 and p 0551 PTCHANDLER General PT Cruiser Discussions 3 06 Dec 2010 04:42 pm
Codes p1684 and p0340 xodeflepgirlox Tech & Performance Forum 1 08 Oct 2010 07:46 pm
Error Code P1684 j_desan Tech & Performance Forum 1 17 Mar 2010 06:37 pm
