Vibration between 2000-3000rpm
Old 29 Oct 2014, 02:23 am
Default Engine Vibration between 2000-3000rpm
I have recently started picking up some vibration when the engine runs between 2000-3000 rpm. It is not hectic, but strong enough that I can feel it through the accelerator pedal. It happens only when there is load on the engine (if I rev it in neutral, nothing happens, it's only when I am driving). This vibration diminishes as the engine warms up. In my opinion power and response is as it should be.
Does anyone have any idea what could cause this. I am just trying to figure if it's something serious that I should be worried about.
Old 29 Oct 2014, 08:36 pm
Default Re: Vibration between 2000-3000rpm
If you let the engine warm up completely first and then drive it does it vibrate under acceleration?
Old 30 Oct 2014, 01:32 am
I have not tried this yet. But what I have noticed is that the vibration does not disappear the moment the engine reaches operating temperature... it take a while longer. I would say it starts diminishing after I have driven about 2.5-3 miles. What do you have in mind as a possible cause? I will test what you suggested too.
Old 30 Oct 2014, 07:55 am
I would need a little history on the PT Cruiser year, turbo or Base, mileage.
What has been done to the PT Cruiser lately?
What was the last time you did a tune up?
Does it vibrate at 2,000 to 3,000 rpm each time after shifting up going up to highway speed?
Old 30 Oct 2014, 08:26 am
mine too, only at 50 to 65 mph overdrive speeds. in thinking cv joints
Old 30 Oct 2014, 08:33 am
Have you checked your tires for balance? PT Cruiser are know for being more sensitive to tire balance than other vehicles.
When was your last tune up?
Old 30 Oct 2014, 09:31 am
Try swapping tires front to rear...
Old 30 Oct 2014, 09:51 am
Steve, it is a 2 liter petrol engine - naturally aspirated - with auto gearbox. It currently has 35 000 miles on the clock. Recently, right before the vibration started, I flushed and changed the coolant and I cleaned the throttlebody by removing it and cleaning all the inside parts with throttlebody cleaner. After that I have changed the oil too, but the vibration was already present. Last tune-up... mmmm... I can't remember (if with "tune-up" you mean timing adjustment etc etc). Yes, it vibrates every time after a shift as well, as long as the rpm are between 2000-3000. It's not really a vibration you can hear, but I feel it in the pedal, probably through the throttle cable. I did notice that my top torsion mount is not in excellent shape anymore and believe that could cause a sort of vibration, but I am not certain that if that was the cause that it would diminish after warming up. So not sure if that's it. Sparkplugs have been changed 17 000 miles ago, but it is platinum plugs so they should still be alright, isn't it?
Old 30 Oct 2014, 09:57 am
plugs and wires, 20k ago, coil pack, new head. I just had tires rotated. seems to coast smooth, vibration with a little pedal to maintain speed, such as grades and such
Old 30 Oct 2014, 10:34 am
LionPT's Avatar
When you cleaned the throttle body, did you remove & clean the IAC (Idle Air Control Valve)..??
You didn't say what year your PT was, but models 2005 & earlier can clean it, 2006 & later have to replace it.
Tags
engine vibration, vibration
Transmission 2000 PT gyrene Tech & Performance Forum 1 20 Aug 2010 08:39 am
2000 PT won't turn over Confucian General PT Cruiser Discussions 3 12 Jul 2010 07:27 am
What changes have been made from 2000? oldretiredfred General PT Cruiser Discussions 14 12 Jul 2009 12:48 am
Limited to 3000rpm thisispops Tech & Performance Forum 1 01 Mar 2009 04:12 pm
350 + HP for around $2000.00 coopj40 Turbo Performance 7 02 Jul 2006 08:01 pm
