Shot motor mounts, again!
Like Tree2Likes
  • 2 Post By rob342
Old 29 Oct 2014, 02:27 pm
VetteJohn's Avatar
Default Shot motor mounts, again!
I've been digging through the old post about motor mounts and have a couple of questions. Car is a 2003, non-turbo, automatic with 176,000 on the clock.
First, why do the mounts keep breaking. I've owned dozens of cars and this is the only one that I've ever had break a mount (lower torque arm really). Was replacing A-arms a few months back and saw the lower torque arm was shot, replaced it. Back under the car doing some other work and it's broken again.
Second, we have a non-turbo but I was wondering if the turbo mounts would work and be a little stronger.
Any help would be great, I'd like to only do this one more time.
John
Old 29 Oct 2014, 02:50 pm
cruserdad1976's Avatar
Default Re: Shot motor mounts, again!
dont think there is any diffrence you can fill them and that will NOT break there is a sticky How to i think or just ask upton
Old 29 Oct 2014, 02:59 pm
you NEED to loosen the upper and lower, stick a jack under the motor, and adjust the jack to match this picture. and then tighten them.
that's 4.685" if you're an 'all american like me that refuses to measure in MM.
11/16= .687, so a rats hair under 4 & 11/16".
if you fill the mounts and dont adjust them you'll just shear the bolts off. well.. if you drive like me you will..
boonie2 and dalandon like this.
Old 29 Oct 2014, 07:02 pm
I would suggest you carefully apply upward force when you are using the jack as you can put unnecessary pressure on the center and transmission mount. I always watch the engine tilting back towards the rear as I am jacking it up and I stop when I see the engine is not tilting anymore.
Old 31 Oct 2014, 08:32 pm
dalandon's Avatar
Never knew about the measurements, good to know thanks
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Motor mounts going bad wasmussen General PT Cruiser Discussions 31 07 May 2015 07:23 pm
Motor mounts - How many and where? rbf7 General PT Cruiser Discussions 10 14 Sep 2012 10:42 am
motor mounts lt4supr Turbo Performance 9 29 Aug 2011 08:34 pm
motor mounts? 2004PTCruiser Tech & Performance Forum 0 31 May 2008 04:50 pm
motor mounts knowyourturbo Classifieds: For Sale/Trade 1 23 Mar 2006 07:36 pm
