2006 PT 2.4 Cut off while driving. no power
Like Tree2Likes
Old 30 Oct 2014, 03:29 pm
Default 2006 PT 2.4 Cut off while driving. no power
All,
I was driving the car leaving work. Before making it out of the parking lot the car cut off. All the warning lights came on. I came to a stop, put it in park and restarted with no issue. Drove for a few miles, then cut off again. This time no power at all. With the key in the ignition, I got nothing. No lights, no power locks, nothing. I waited about 5 minutes and was able to start with no issue. I have not checked the starting/charging system as I have never had an issue previously. The battery is roughly a year old. I highly doubt it is related to the starting/charging system as it runs fine once started and lacks no power. I have fuel, spark, and ignition. I have always had problems with a slight power loss while running either heat or ac. But have had this issue for at least 50k with no affect other than a higher rpm reading. This could have been a sign of problems to come..I know.I have read post concerning a few options such as both the crank and cam sensors, PCM, and timing belt. Can anyone provide input as to what may be the root cause. I have a feeling it is sensor or electrical/computer related. Also is there any video or step by step guidance on replacing either the crank sensor or timing belt? Any assistance is greatly appreciated.
Old 30 Oct 2014, 06:22 pm
Default Re: 2006 PT 2.4 Cut off while driving. no power
Not clear what the status is right now - you made it home or not?
Check engine light on?
Has your radio display acted up? (That's a sign of bad ignition switch).
Find an AdvanceAuto or such and have them pull up trouble codes.
Old 30 Oct 2014, 06:59 pm
Thanks for the reply..
I did make it home, thanks for asking. At first the computer appeared to have reset. The radio and all gauges turned on and off, the radio and compass appeared to have reset. No CEL was present after I was able to restart in each instance. However it did illuminate during the drive home. I have not had a chance to pull the codes. I plan to check the battery, alternator, and starter wire connections in the morning. Although I don't feel these to be the cause I wanted to rule them out. I've done researched and found a video on replacing the cam sensor. I still need replacement info on the crankshaft, and timing belt if necessary. Also any other ideas you can come up with. I don't want or mean to go overboard. However I'm mechanically inclined and feel I have the skills necessary to perform the repairs myself. I really just need help in terms of a diagnosis. Any assistance is greatly appreciated.
Old 30 Oct 2014, 08:05 pm
The ignition switch can be damaged by too much pressure from the ignition key if you have too many keys attached to your key ring. How many keys are on your key ring when you are driving your PT Cruiser?
Old 30 Oct 2014, 08:07 pm
You might want to introduce yourself if you have not done it yet and there is a library with the information you need on this forum.
mityqwik likes this.
Old 30 Oct 2014, 10:34 pm
dalandon's Avatar
Either the key switch or a bad battery connection thats where I would start
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Old 31 Oct 2014, 09:19 am
Thanks to all for replying..
I have check voltage on the battery and alternator. They checked out. When I researched how to check the ignition, I was referred to the PCM. Is anyone familiar with how to inspect, repair, and/or replace the ignition system or PCM? Could the ignition itself(where the key is inserted) be defective?
Old 31 Oct 2014, 10:40 am
YES. Happens quite a bit.
Old 31 Oct 2014, 11:03 am
I don't think so. They don't usually cut off or restart very easily. When was the terminals last cleaned. If at new battery install. Then it could well be your issue.
Old 31 Oct 2014, 08:02 pm
All,
Is your engine light on? If so what are the engine trouble codes? If the PCM was failing you would think that it would trigger a trouble code.
2006 PT Cruiser no power to power seat paradyne64 General PT Cruiser Discussions 5 29 Dec 2016 02:54 am
2006 pt cruiser loses power then surges while driving grpch75 Tech & Performance Forum 4 21 Jul 2014 02:05 pm
2006 - Turn signal/driving lights Tarnishedknight Tech & Performance Forum 10 02 Sep 2010 08:23 am
No Power When Driving?? What Next!! NewPTCruiserInPA Tech & Performance Forum 18 02 Sep 2008 06:31 pm
Power locks locking/unlocking while driving? vk General PT Cruiser Discussions 16 28 Feb 2005 12:06 pm
