NEED HELP 2006 PT CRUISER CRANKS BUT WON'T START!
Old 04 Nov 2014, 04:00 pm
Exclamation NEED HELP 2006 PT CRUISER CRANKS BUT WON'T START!
2 Days from today, in the morning I was getting ready to leave from my house. I was backing up my parking lot and when I stopped to get ready to change from reverse to drive my car shut off on me. The check engine light was on before it shut off. I'm not good with cars so I don't know what the problem might be. Please help :/
Old 04 Nov 2014, 04:04 pm
Default Re: NEED HELP 2006 PT CRUISER CRANKS BUT WON'T START!
Welcome to the forums, Details are needed.
Year , Miles
did you use a code reader?
someone will be with you shortly, Enjoy the elevator music.
Old 04 Nov 2014, 04:14 pm
My car is a 2006 Pt cruiser with 111,208 miles. I did not use a code reader.
Old 04 Nov 2014, 04:22 pm
cruserdad1976's Avatar
well it COULD be a lot of things
First thing is the timing belt if it has not been done the milles are right there
after that lots of guesses you need to get a code reader and check it out or have some one check the timing belt--if it is the timing belt you need to find some one who is knowledgable on the PT cruser and it will be a Big expense ( between $750-$1200) change the water pump and tensioners when you do the timing belt
Old 04 Nov 2014, 04:34 pm
Ok thanks, I'll just have to get someone to take a look at the car.
Old 04 Nov 2014, 05:29 pm
Could very well be.
One thing to try - get some "starting fluid" and spray in intake and try to start the car - if the engine "coughs", timing belt is okay, and you have some spark.
Old 04 Nov 2014, 05:35 pm
Great idea but i kind of get the idea that the op is not a car person and probaly would ahve no idea where to spray the starting fluid
Old 04 Nov 2014, 05:54 pm
That also could very well be....
Cranks but no start? C300392 Tech & Performance Forum 4 15 Apr 2016 07:58 am
Cranks, won't start (bad PCM ???) dxv77 General PT Cruiser Discussions 14 26 Jul 2015 05:19 pm
Cranks but want start stickkman99 General PT Cruiser Discussions 8 04 Aug 2013 12:00 am
Cranks no start solved gimcrack Tech & Performance Forum 7 21 Jan 2013 06:51 pm
Removed starter relay, Now Pt cruiser Cranks but wont start!! iponnet22 General PT Cruiser Discussions 2 13 Oct 2012 11:26 pm
