Cruise control possessed
Like Tree3Likes
Old 04 Nov 2014, 08:36 pm
Thumbs down Cruise control possessed
I've been looking online for 2 weeks now and cannot find anyone who has experienced my problem. I have a 2002 Pt Cruiser, 5-speed. Everything was great and working til recently. My cruise control stopped working, sort of...
It will work if I put the key in run position, turn cruise light on, then start car. If I try to do it the usual way, the light won't come on and the cruise doesn't work. Will only turn off and on while in run position, not while driving... Any ideas???? No codes, unhooking battery didn't help..
Old 04 Nov 2014, 08:44 pm
Default Re: Cruise control possessed
Sniper does your radio cut out randomly on you?
Old 04 Nov 2014, 09:25 pm
That is peculiar.
Cruise uses engine vacuum to work, and there's no vacuum until engine starts - there could be a clue there, but not sure what the clue is...
Old 04 Nov 2014, 09:36 pm
true the cruise is vacuum controlled, once the computer registers you have turned it on, i guess i should also chime this in, when my engine blew , my cruise had the EXACT same symptom, cruise would only chime in before the car was actually started, after it was started it would not turn on, it was like the computer knew something, but would not give a code or a CEL.
Old 04 Nov 2014, 09:42 pm
If it only works with certain positions of the switch then I would say start there. Vacuum has nothing to do with the switching. Thats electrical. Could be in the main wire connector in the column. Just a guess.
NitroPT likes this.
Old 04 Nov 2014, 09:46 pm
Think it could be the column ground by chance?
Old 04 Nov 2014, 10:00 pm
I'd think that wold impact more than just cruise...
NitroPT likes this.
Old 04 Nov 2014, 10:38 pm
I can't say no, but I would lean towards ignition switch or the wiring going to it. Again just my guess. Just seems funny the switch position is the common denominator. Wiring is not my strong suit.
Old 05 Nov 2014, 02:11 am
I would suggest checking the cruise control switch, input speed sensor, output speed sensor, transmission and/or clutch switches, vehicle speed sensor, the vacuum servo and vacuum system that can cause the cruise control and light to shut off. The PCM controls the system for speed control by using these components.
How many miles do you have on it and when was the timing belt replaced if it was?
Old 05 Nov 2014, 02:31 am
podo2000's Avatar
I just replaced the PCM on my 05. It was a faulty unit. It caused a similar issue with my cruise control. Got another replacement and everything works fine. Something to look int maybe?
2004 PTGT 135Kmiles
Cruise Control jaded13640 General PT Cruiser Discussions 4 15 Aug 2014 09:17 am
cruise control hillbilly678 General PT Cruiser Discussions 3 26 Jan 2013 06:34 pm
cruise control remington Tech & Performance Forum 3 19 Sep 2011 05:41 pm
cruise control cook General PT Cruiser Discussions 7 30 Dec 2003 09:36 am
Cruise Control TurboNNN General Turbo Discussions 10 07 Jul 2003 02:37 pm
