LED conversion
Like Tree2Likes
Old 05 Nov 2014, 12:16 pm
Default LED conversion
Hopefully this is the right place for this...
My 2008 Cruiser occasionally blows out its tail lights. Apparently, water splashes up and gets into the tail lamp and the cool water blows up the hot bulbs. I'm interested in replacing the incandescent bulbs with LEDs.
I expect that the problem will be that the flasher may not blink the turn signals and emergency flasher. On the other hand, the flasher MIGHT be electronic and may not need a load to blink the lights.
Has anybody converted their lights to LEDs? Any tips?
Old 05 Nov 2014, 01:20 pm
Default Re: LED conversion
If water is getting to the actual lamps, you should fix the lens first.
Or if water is getting on the pigtails and shorting them out, you should fix that.
Just putting led's in will only temporarily fix the issue.
Old 05 Nov 2014, 04:35 pm
soonercruiser's Avatar
Cool Re: LED conversion
THIS ^^^^
Sounds like your biggest problem is the tail light assembly is leaking - not sealed!
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 05 Nov 2014, 04:49 pm
cruserdad1976's Avatar
silcone is your freind seal it up or you will not be gaining anything
Old 05 Nov 2014, 06:36 pm
For what LED bulbs cost, you could (and should) replace your tail light housings with ones that don't leak.
Old 05 Nov 2014, 07:17 pm
Danny7627's Avatar
I have a second generation PT and the can-bus electrical system. Adding LED's maybe a problem for the rear lights. You may want to read this earlier post.
Front Turn Signal Lights Turn On and Off When Applying Brake?
Keep in mind, I have added all kinds of LED's to the front, back and interior of my car with no problem but the rear lights brake and tail lights went a bit haywire the LED's.
I believe it had something to do with the low draw from the LED's.
Definitely, get some clear silicone for the tails and make sure the screw is lined up with the clip correctly on the tail light assembly for a snug fit.
Good Luck
Dan
2008 Convertible Turbo -lite
2007 Touring N/A Boneyard
Old 05 Nov 2014, 08:22 pm
Thanks for the replies everyone.
I did seal the lamps with silicone and that helped a lot and may have (should have) "fixed" the problem but I'm not entirely confident that is as reliable as I'd like. My daughter broke a lamp and the replacement does seem to be sealed better but then I'm not sure I can count on another one as well constructed. Of course, I might be a little paranoid.
The unsaid interest in this is that I've replaced most of my bulbs with LEDs in another char but I need a couple more to finish it and it's not worth the shipping for such a small order! Getting LEDs for the Cruiser could make it worthwhile.
I've been using Superbright (https://www.superbrightleds.com) and then have a listing for LEDs for 2008 Cruisers so I'm assuming they are CAN-BUS compliant. That might be a rash assumption. They also list some flashers to use but I understand that the flashers are 'built in'. Of course, the flasher could be an issue with LEDs, too.
From Danny's link, it sounds like using LEDs is more trouble than they're worth on the Cruiser and making sure the lamps are sealed is the real ticket. Does that sound right?
Old 05 Nov 2014, 08:56 pm
does to me
Old 05 Nov 2014, 09:25 pm
Red face Re: LED conversion
DON!
But that was my "inferred" point with the post you corrected me on!
Old 05 Nov 2014, 09:30 pm
Yes!
But again, just replacing bulbs with a Gen 2 could be problematic.
I have 3 of my 4 Cruisers as Gen 2s, that all plug&played without a hitch when I bought the whole tail light assembly.
You may want to consider that if your current plan doesn't work out.
Occassionally, salvaged LED assemblies do show up for sale on several PT forums.....sometime when someone is "parting-out" a PT.
RWD Conversion? beansracing Tech & Performance Forum 12 15 Jun 2013 02:18 pm
New Conversion TheRed Welcome New PT Cruiser Members 6 26 Jul 2011 10:20 am
CNG conversion? georgespt Tech & Performance Forum 6 06 Jul 2011 10:51 am
conversion to Gt PTcruzer02 General Turbo Discussions 18 04 May 2009 02:04 pm
HID Conversion Kit Sam2627 Exterior Accessories Forum 2 26 Jan 2008 02:36 pm
