Need some help diagnosing a small issue
Old 06 Nov 2014, 03:57 am
Default Need some help diagnosing a small issue
Check engine light on. Scanned says its a P3003 cylinder misfire.
Changed plugs,and wires.
Took to mechanic spent two hours, couldn't figure it out sent me on my way.
Notes:
1. while night driving my highbeams get brigher than lower than brighter again(poss alternator issue?)
2. While in 5th gear going aprox 80-90km (aprox 50mph) the check engine light blinks.
3. When i run my AC at an idle the rmp drops then spikes than evens out..happens every 2 mins or so
I am not a super smart car guy,and not rich so im trying to figure this out on my own. Internet search puts in in way over my head. Anyone have a similar experience or can shed some light on it?
Old 06 Nov 2014, 04:20 am
Default Re: Need some help diagnosing a small issue
Notes:
Start with a simple tune up, Plugs wires.
use code reader to clear codes after work is done.
Old 06 Nov 2014, 05:57 am
Notes:
What year
How many miles
Work done Maint?
Parts changed
and you are from?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 06 Nov 2014, 06:31 am
LionPT's Avatar
Notes:
3. When i run my AC at an idle the rmp drops then spikes than evens out..happens every 2 mins or so?
From these symptoms, it's an electrical problem...start off by checking all your fuses & relays, ground wires...especially the one to the right of the battery that connects under the fender...then have the battery load tested.
Old 06 Nov 2014, 08:55 am
I am suggesting you might have two problems . First thing I would suggest is to take both cables off the battery and clean the contacts on both the battery cables and the battery posts. Also take the caps off the battery and see if the battery fluid level is low. You might find it low on the cells next to the positive post and next to the negative post. If you do just fill it back up with distilled water. After you have done this take the PT Cruiser to Sears or someplace where they can do a battery load test as LionPT suggests for free. Not just check the voltage but check to make sure the battery can handle a load from running A/C, headlights, etc. When disconnecting the battery make sure you disconnect the negative side first and then the positive side. Then when connecting put on the negative side first and then the positive side.
I would suggest on the 2nd problem to take a engine compression check on all cylinders. Your engine trouble code indicates a possible compression problem in one of the cylinders.
cruserdad1976 likes this.
Old 06 Nov 2014, 09:24 am
Also a faulty fuel injector could cause a mis.
Old 06 Nov 2014, 09:52 am
Agree there could be 2 issues. Take off battery terminals and clean them and put them back on tightly, and have battery and charging system checked ( for free).
Plugs and wires was a very good first step.
Try adding an injector cleaner to the gas, like Lucas.
Old 06 Nov 2014, 10:30 am
cruserdad1976's Avatar
also on the battery ends sometimes the cables them selfs will get nasty and need replaced a bad battery in a PT causes all kinds of Griminlins
Old 06 Nov 2014, 03:11 pm
I personally did the wires and plugs. Cleared the codes they came back that day.
Old 06 Nov 2014, 03:12 pm
Originally Posted by JoeX View Post
What year
How many miles
Work done Maint?
Parts changed
and you are from?
Its 2003. I bought the car Cert/Etested. Problem came two weeks after having it. Ontario Canada
Diagnosing sputtering start / shaking while idle q1h Tech & Performance Forum 5 14 May 2012 08:26 pm
Small video of my pt junkno General PT Cruiser Discussions 3 09 Mar 2005 01:20 am
Small world, isn't it Ken... Gary04GT General PT Cruiser Discussions 18 12 Nov 2003 04:34 pm
Small details raphael General PT Cruiser Discussions 0 01 Dec 2002 10:17 am
