Strange electronic"glitch"
  • 1 Post By CREWZIN
Old 07 Nov 2014, 11:10 am
Default Strange electronic"glitch"
I have a 2.2 diesel- and love it.56 plate- only 41,000 genuine miles.Recently as I drive along suddenly ALL the warning lights illuminate- as if the key was in the ignition prior to turning the key to start the engine.
At the same time the fuel and temperature dials zero- including the rev counter and speedometer
This lasts 2 seconds- and then all returns to normal- EXCEPT the seat belt warning light stays illuminated for 20 seconds before it also disappears.
Sometimes after this hie engine management light stays on.
I went to a local Chrysler dealer- they ran a diagnostic test- and found nothing wrong.Any ideas would be much appreciated
Old 07 Nov 2014, 11:48 am
Default Re: Strange electronic"glitch"
When something like that happens on this side of the big pond with the gas engines, it usually turns out to be bad grounding or ignition switch. Check the connections to your battery for tightness and and corrosion. Trace the ground wire and make sure that's OK. Wiggle the ignition switch to see if that has any affect and adjust the steering wheel up and down as sometimes the wiring harness running down the steering column pulls on the wires.
There's other possibilities also like the harness going into the fuse box or bad grounding of your gauge package.
Old 07 Nov 2014, 12:10 pm
LionPT's Avatar
Electrical? Troubleshooting
Old 07 Nov 2014, 09:56 pm
what year is your PT Cruiser? A little history of your PT Cruiser would help such as what problems you have been having recently with it before the strange electronic glitch started.
Old 10 Nov 2014, 07:31 am
Thanks for the replies. The car is a 56- no other issues at all with it
Low mileage-- genuine 41,000
Just weird how the dashboard lights up like a Christmas tree!
All ideas will be followed up gratefully
"G" fell off my "Touring"... rockandroller The Detail Shop 19 03 Feb 2015 07:05 pm
2002 Pearl Almond Limited Pt "Custom Route 66 " Edition rt66pt Classifieds: For Sale/Trade 59 04 Mar 2013 12:49 am
strange idle problem '06 Turbo "Lite" Farrar Tech & Performance Forum 6 02 Jun 2011 06:59 pm
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
