Math Problem
Like Tree7Likes
  • 5 Post By NitroPT
  • 1 Post By NitroPT
  • 1 Post By NitroPT
Old 09 Nov 2014, 03:58 pm
Default Math Problem
I stink at math but i do know max variation between cylinders on compression is 25%. Now I am getting 195 200 190 185 compression readings. Dose that fall in the 25% range? This is with a dead cold engine. 130k on engine. Just put a new head gasket in.
2002 2.4 auto 130k and still going.
Old 09 Nov 2014, 04:17 pm
Default Re: Math Problem
The highest is *195 lowest 185, 195 x .75 = 146.25 which would be 25%
Your *200 is either inaccurate or you have a lot of carbon or a valve overlap problem with the cam shaft timing.
Then your post from cyd #1 left to right.. #1 and #2(if 2 is actually corrected 195) look good #3 and #4 185 (190x.75+142.50) 185 x.999=184.81/round up 185 which is 1%
You should really re-due your compression check:
Do no more than 5 engine cycles per cylinder.
Make sure the throttle body is wide open
If you get #1-4 with 190+/-10psi you have a pretty good result.
You could follow up by doing a wet compression test and then even a cylinder leak down for a total engine analysis.
Last edited by NitroPT; 09 Nov 2014 at 04:38 pm. Reason: spelling and added the word round up
Old 09 Nov 2014, 06:57 pm
Thanks. I did that test with the upper intake manifold off. And when I spun the engine I counted 10 compression strokes.
Old 09 Nov 2014, 07:04 pm
10 is way to many no more than 5 maximum.
You have my number call if you need help anytime!
be prepared I see a member that has long story responses on threads replying as we read this.
scatgo1 likes this.
Old 09 Nov 2014, 08:43 pm
Hey Nitro. If a Pt Crusier left LA at noon traveled at a average speed of 55, blew a head gasket and got laid up for 48 hours for repairs what time would it get to NYC......LOL
Old 09 Nov 2014, 10:16 pm
UptownSport's Avatar
And if it's 26% are you going to replace the engine??
Taking compression in absence of issues is a fool's errand!
Old 09 Nov 2014, 11:54 pm
And how was Rome built? Brick by brick!
A compression check is always a good start. I have always included this with any vehicle new I ever owned.
IOwnMugsy likes this.
Old 10 Nov 2014, 12:40 am
Its a trick question
The answer is the same time.
Old 26 Nov 2014, 09:03 pm
Had a big issue. When replacing head gasket the gasket surface on top of the engine didn't look all that good. Now we know how good it is.
I think I hold out till its 27%
AC problem became Overheating problem BilltheBrewer Tech & Performance Forum 1 23 Jul 2014 11:31 pm
Window problem and AC problem kaypriest Tech & Performance Forum 30 04 Jul 2014 07:42 am
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
