Blown Headgasket?
Old 09 Nov 2014, 07:47 pm
Default Blown Headgasket?
I'm at a loss, Been having problems with the PT having a misfire that went away and now comes and goes but is there at idle (muffled popping sound in exhaust). I have pressure tested the cooling system and at 17 PSI it dropped to 14 in 4 mins, After doing the pressure test the misfire got worse to the point of tripping a P0300 code. New plugs & wires a year ago. Noted that the plugs had a green hue to them when I had em out last weekend. Cleaned and regaped at 40. Any ideas? This video is of the car once at operating temp.
https://www.facebook.com/video.php?v=10204141133867108
Silver Bullet - 2001 PT Cruiser Limited, 5-Speed, 2.4 N/A, No mods yet just fixing her up slowly
Old 09 Nov 2014, 08:50 pm
Default Re: Blown Headgasket?
Tested the coolant for o2?
Old 09 Nov 2014, 09:50 pm
You having overheating problems??
How many miles in that year since plugs & wires were changed?
What does coolant look like?
What does oil look like?
Old 09 Nov 2014, 11:17 pm
Was once when I blew a rad hose. Had to limp it to a gas station and it got close the red a few times. Oil is clean. About 20thou km. Collins was changed a year ago and now looks crappy . No signs of oil in it tho
Old 09 Nov 2014, 11:18 pm
Don't have a tester to test the coplant for co
Old 10 Nov 2014, 04:55 pm
boonie2's Avatar
Any moisture out of the tailpipe?
Take off the oil filler cap and see if there's moisture there?
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 10 Nov 2014, 07:50 pm
Do all the spark plugs have coolant deposits on them?
Old 10 Nov 2014, 11:14 pm
So, take it to a mechanic that does.....
Old 11 Nov 2014, 09:37 am
You can by you a test kit to check for exhaust gasses..
Headgasket / Overheating PTCommuter Tech & Performance Forum 6 07 Apr 2014 10:12 pm
Oil in Coolant, headgasket? JSarge Tech & Performance Forum 7 27 Jan 2014 09:55 am
Headgasket R&R UptownSport Tech & Performance Forum 14 01 Jan 2014 07:56 pm
Oil Leak from Headgasket VNT General PT Cruiser Discussions 8 04 Dec 2012 09:28 pm
Headgasket oil leak adamf123 Tech & Performance Forum 10 22 Apr 2008 12:57 pm
